Heya, I have recently been raped with the idea of buying a second car, and have found quite possibly the easiest solution for it, however, I know shit all about cedrics, and less about a Y30
Could someone tell me some shit about them? Why I should/shouldn't buy one?
This thing is like $300 with no rust ANYWHERE, perfect interior if a bit faded, only requiring rego, service and a fuel pump.
It's auto and a VG30. Engine doesn't concern me but the auto box might... Are they any sort of decent? I know it'll need a filter service kit put through it, but that's normal.
What else should i consider in regards to this car?
https://www.sau.com.au/forums/topic/306533-py30-goodness/
its been sitting for a while. and its a nissan. I'm yet to experience nissan autos.
if i do it, it will be zoku'd the f**k out of. as legal as i can go, of course. 15x10" banded wheels, prob stretched 205s, flared guards. dumped. fake oil cooler. crazy little metre-long exhaust zig-zag. then respray. and then interior to a VIP style :P maybe.
will drive it normal for a while, but yeah.
so you don't think it'll have any problems ay?
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5069070
OoOoOo ultimate sleeper!!
Maybe, maybe. Would be easier to fit all z32t running gear i think though. how sick would that be... zoku'd cedric capable of epic skids.
are there any similarities in other platforms that might be able to run coilovers?
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5069737
Hey, if you dont want it I will take it.
The Y30 looks oldschool. Would look phat with my nice dishy 15's on it
I have a Y31 Cima, and Love it.
Got some nice JIC coilovers aswell, but havent tested the car out with them in as yet.
If it has a VG30, it should have the same gearbox as a 300zx, I think it is a RE40..... or something a rather.
Gearbox definately has potential for drag use that is for sure.
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5072495
Hi Jason, the Y30 is a great car. I had one with a late model VG30E twin throttle body. The Autos are a tough box, never had any problems with it, even when I smashed the diff.
They are very truck like in their build. Big solid rear axle, big trailing links, big rails, steering box, none of this rack business!
This means that majority of parts from other models such as the R31, S13, etc don't bolt up. The diff is shared with the 720 ute as is the steering box and knuckles. The Front struts can be used from a Z31 'Californian' with 5 stud hubs.
Any VG or RB will bolt in.
Here is my old car. Crossmember was 35mm off the ground :). 18' Lensos and a trimmed Volvo 244 GT front lip.
Edited by SABBAi
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5072522
^^ TOUGH!!
Okay so I had a look today. She's rough but there's no rust, the panels are 95% straight, and basically all body damage is easily fixable. BUT, haven't heard it run, don't know if electrics work or not, and it's missing a passenger side window and front windscreen. apart from that, if i get it it's gonna look bombed.
Big question here:
How hard is it to find parts for these vehicles?
Edited by Dorigecko
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5078196
I know in Melbourne a self serve wrecker has 3 of them in various states. I imported bits from japan from www.importmonster.com.au.
There aren't many around to be honnest and when I had it I got most of the good bits from the local wreckers. You'll find that the factory paint comes up brilliantly with a detail. 2pac from factory in 83.......... Aw Yeah!!!
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5079249
    • The boot notch on the GK Tech rods is different to OEM yes. You'll find a solution. They are a good rod, I have used many of them for various setups, and no they are not ' just for drift cars', they are fine as an OEM replacement. Same goes for the tie rod ends although I found they transmitted a huge amount of NVH a normal balljoint masks, making it feel like there was something loose or knocking, even though there wasn't. If you used the same pieces on each side, no reason one angle should be different to the other side. Have you checked ride heights/measured the angles? Or just visual? Your alignment will be massively out of whack yes. Up to you; it is worth taking the time to learn wheel alignments and do it yourself. I have never had better wheel alignments and I haven't taken my car to a shop for, dunno...many many years. Spend a few hundred on equipment, do alot of research via online articles, youtube vids, and "trial and error" on setups. Eg, set it with too much toe-out, toe-in, too much or little caster, drive the same stretch of awesome twisty mountain road each time, learn how they feel and how the car's handling has reacted to your changes.
    • Won鈥檛 be hard to beat them. 馃ぃ Farken sponge cakes!
    • Nah I did not will have to another time. I only installed a blitz return flow FMIC probably 1000kms ago. When I took the old piping off there was basically no oil in piping. At this stage it has to be valve stem seals. When I roll down a big hill in gear and then throttle down the bottom, I get the same puff of smoke.
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
