Heya, I have recently been raped with the idea of buying a second car, and have found quite possibly the easiest solution for it, however, I know shit all about cedrics, and less about a Y30
Could someone tell me some shit about them? Why I should/shouldn't buy one?
This thing is like $300 with no rust ANYWHERE, perfect interior if a bit faded, only requiring rego, service and a fuel pump.
It's auto and a VG30. Engine doesn't concern me but the auto box might... Are they any sort of decent? I know it'll need a filter service kit put through it, but that's normal.
What else should i consider in regards to this car?
https://www.sau.com.au/forums/topic/306533-py30-goodness/
its been sitting for a while. and its a nissan. I'm yet to experience nissan autos.
if i do it, it will be zoku'd the f**k out of. as legal as i can go, of course. 15x10" banded wheels, prob stretched 205s, flared guards. dumped. fake oil cooler. crazy little metre-long exhaust zig-zag. then respray. and then interior to a VIP style :P maybe.
will drive it normal for a while, but yeah.
so you don't think it'll have any problems ay?
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5069070
OoOoOo ultimate sleeper!!
Maybe, maybe. Would be easier to fit all z32t running gear i think though. how sick would that be... zoku'd cedric capable of epic skids.
are there any similarities in other platforms that might be able to run coilovers?
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5069737
Hey, if you dont want it I will take it.
The Y30 looks oldschool. Would look phat with my nice dishy 15's on it
I have a Y31 Cima, and Love it.
Got some nice JIC coilovers aswell, but havent tested the car out with them in as yet.
If it has a VG30, it should have the same gearbox as a 300zx, I think it is a RE40..... or something a rather.
Gearbox definately has potential for drag use that is for sure.
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5072495
Hi Jason, the Y30 is a great car. I had one with a late model VG30E twin throttle body. The Autos are a tough box, never had any problems with it, even when I smashed the diff.
They are very truck like in their build. Big solid rear axle, big trailing links, big rails, steering box, none of this rack business!
This means that majority of parts from other models such as the R31, S13, etc don't bolt up. The diff is shared with the 720 ute as is the steering box and knuckles. The Front struts can be used from a Z31 'Californian' with 5 stud hubs.
Any VG or RB will bolt in.
Here is my old car. Crossmember was 35mm off the ground :). 18' Lensos and a trimmed Volvo 244 GT front lip.
Edited by SABBAi
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5072522
^^ TOUGH!!
Okay so I had a look today. She's rough but there's no rust, the panels are 95% straight, and basically all body damage is easily fixable. BUT, haven't heard it run, don't know if electrics work or not, and it's missing a passenger side window and front windscreen. apart from that, if i get it it's gonna look bombed.
Big question here:
How hard is it to find parts for these vehicles?
Edited by Dorigecko
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5078196
I know in Melbourne a self serve wrecker has 3 of them in various states. I imported bits from japan from www.importmonster.com.au.
There aren't many around to be honnest and when I had it I got most of the good bits from the local wreckers. You'll find that the factory paint comes up brilliantly with a detail. 2pac from factory in 83.......... Aw Yeah!!!
https://www.sau.com.au/forums/topic/306533-py30-goodness/#findComment-5079249
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
