hey guys
i was driving home one morning giving it a heap , i didnt notice the tempreture but when i looked down it was on H !
i was about 300m from home so i put it in 5th and cruzed very slowly. i opened the bonnet and it was pissing out steam and coolant was dripping out from the back of the motor but wasnt exactly sure where.
later on i got in there and had a look . i narrowed it down and i think i found where it is but cant get rite in there . it just under the last manifold at the back of the motor about 200mm down. ive tried to look underneath but the starter motor is in the way and i cant get the last bolt off ! and i dont want to start taking off the manifolds coz i no its a big job!!
i no that this isnt much explanation but hopefully one of use have had the same problem and use could help ????
even if use could recomend me a place to go in perth that is a specialist in the whole cooling side of the motors.
if use can help at all, it would be much appreciated!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/306580-big-problem/
Nice work champ :)
Try harder to get that last bolt of for the starter motor...you got one off and gave up...you were halfway there.
Manifolds aren't a massive job either, 12 bolts and some vacuum and water pipes.
Pic of side of the block...probably just busted a hose, or it's come loose:
http://img.photobucket.com/albums/v20/IIIRII/DSC00665.jpg
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067788
yeah ill give it another shot tommorrow but its a really hard place to get to. its kind of im possible to get enough leverage and force to get it off lol!!
is it possible i have cracked a manifold or anything like that ?????
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067822
It will be either the heater hose that runs behind the engine or the rubber hose that comes off a small metal pipe that sits under the back of the intake manifold (possibly turbo water feed, can't remember).
I had the heater hose back there let go on the dyno :cool: pricks of things to change! and they're a molded hose if you really want to get picky.
Edited by bubba
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5068381
done ! i tryed for 2 nights trying to get that starter motor bolt off ! lucky my mate could do it !
it was just a small pipe under the manifold . was a prick to get into but i just made it happen ! (some how) hah
just another question . . . i couldnt of done a head gasket or something could i ??
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072084
If you're concerned about headgasket, check for oil/water out the exhaust, check radiator for oil mixing in with the water and check the sump for water mixing in with the oil.
Maybe a compression/leakdown test if you're really worried?
I've had my RB30DET pretty hot.. blew a heater hose on the road one time and also boxing day burnouts last year water temp hit 105deg (this was well off the top of the stock gauge), 110deg - get worried, 120deg - boiling coolant.. this is probably where you will start to warp the head.
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072489
Glad to see you have got it fixed. Well done.
Now, call me a miserable old git, but I cannot help myself ... ... ... ...
I can ignore the "no" rather than "know", as an example of Twitter-youth mangling of our language. But the misuse of "use" , instead of "you" - for God's sake!!! It is the same number of letters, so it is no easier to type!! Just use the right word, why don't you???
Please, to save my blood pressure and be kind to the older generation, use "you" and not "use", because misuse of "use" is not useful!
Cheers. :D
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5073205
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
