hey guys
i was driving home one morning giving it a heap , i didnt notice the tempreture but when i looked down it was on H !
i was about 300m from home so i put it in 5th and cruzed very slowly. i opened the bonnet and it was pissing out steam and coolant was dripping out from the back of the motor but wasnt exactly sure where.
later on i got in there and had a look . i narrowed it down and i think i found where it is but cant get rite in there . it just under the last manifold at the back of the motor about 200mm down. ive tried to look underneath but the starter motor is in the way and i cant get the last bolt off ! and i dont want to start taking off the manifolds coz i no its a big job!!
i no that this isnt much explanation but hopefully one of use have had the same problem and use could help ????
even if use could recomend me a place to go in perth that is a specialist in the whole cooling side of the motors.
if use can help at all, it would be much appreciated!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/306580-big-problem/
Nice work champ :)
Try harder to get that last bolt of for the starter motor...you got one off and gave up...you were halfway there.
Manifolds aren't a massive job either, 12 bolts and some vacuum and water pipes.
Pic of side of the block...probably just busted a hose, or it's come loose:
http://img.photobucket.com/albums/v20/IIIRII/DSC00665.jpg
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067788
yeah ill give it another shot tommorrow but its a really hard place to get to. its kind of im possible to get enough leverage and force to get it off lol!!
is it possible i have cracked a manifold or anything like that ?????
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067822
It will be either the heater hose that runs behind the engine or the rubber hose that comes off a small metal pipe that sits under the back of the intake manifold (possibly turbo water feed, can't remember).
I had the heater hose back there let go on the dyno :cool: pricks of things to change! and they're a molded hose if you really want to get picky.
Edited by bubba
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5068381
done ! i tryed for 2 nights trying to get that starter motor bolt off ! lucky my mate could do it !
it was just a small pipe under the manifold . was a prick to get into but i just made it happen ! (some how) hah
just another question . . . i couldnt of done a head gasket or something could i ??
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072084
If you're concerned about headgasket, check for oil/water out the exhaust, check radiator for oil mixing in with the water and check the sump for water mixing in with the oil.
Maybe a compression/leakdown test if you're really worried?
I've had my RB30DET pretty hot.. blew a heater hose on the road one time and also boxing day burnouts last year water temp hit 105deg (this was well off the top of the stock gauge), 110deg - get worried, 120deg - boiling coolant.. this is probably where you will start to warp the head.
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072489
Glad to see you have got it fixed. Well done.
Now, call me a miserable old git, but I cannot help myself ... ... ... ...
I can ignore the "no" rather than "know", as an example of Twitter-youth mangling of our language. But the misuse of "use" , instead of "you" - for God's sake!!! It is the same number of letters, so it is no easier to type!! Just use the right word, why don't you???
Please, to save my blood pressure and be kind to the older generation, use "you" and not "use", because misuse of "use" is not useful!
Cheers. :D
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5073205
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
