hey guys
i was driving home one morning giving it a heap , i didnt notice the tempreture but when i looked down it was on H !
i was about 300m from home so i put it in 5th and cruzed very slowly. i opened the bonnet and it was pissing out steam and coolant was dripping out from the back of the motor but wasnt exactly sure where.
later on i got in there and had a look . i narrowed it down and i think i found where it is but cant get rite in there . it just under the last manifold at the back of the motor about 200mm down. ive tried to look underneath but the starter motor is in the way and i cant get the last bolt off ! and i dont want to start taking off the manifolds coz i no its a big job!!
i no that this isnt much explanation but hopefully one of use have had the same problem and use could help ????
even if use could recomend me a place to go in perth that is a specialist in the whole cooling side of the motors.
if use can help at all, it would be much appreciated!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/306580-big-problem/
Nice work champ :)
Try harder to get that last bolt of for the starter motor...you got one off and gave up...you were halfway there.
Manifolds aren't a massive job either, 12 bolts and some vacuum and water pipes.
Pic of side of the block...probably just busted a hose, or it's come loose:
http://img.photobucket.com/albums/v20/IIIRII/DSC00665.jpg
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067788
yeah ill give it another shot tommorrow but its a really hard place to get to. its kind of im possible to get enough leverage and force to get it off lol!!
is it possible i have cracked a manifold or anything like that ?????
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067822
It will be either the heater hose that runs behind the engine or the rubber hose that comes off a small metal pipe that sits under the back of the intake manifold (possibly turbo water feed, can't remember).
I had the heater hose back there let go on the dyno :cool: pricks of things to change! and they're a molded hose if you really want to get picky.
Edited by bubba
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5068381
done ! i tryed for 2 nights trying to get that starter motor bolt off ! lucky my mate could do it !
it was just a small pipe under the manifold . was a prick to get into but i just made it happen ! (some how) hah
just another question . . . i couldnt of done a head gasket or something could i ??
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072084
If you're concerned about headgasket, check for oil/water out the exhaust, check radiator for oil mixing in with the water and check the sump for water mixing in with the oil.
Maybe a compression/leakdown test if you're really worried?
I've had my RB30DET pretty hot.. blew a heater hose on the road one time and also boxing day burnouts last year water temp hit 105deg (this was well off the top of the stock gauge), 110deg - get worried, 120deg - boiling coolant.. this is probably where you will start to warp the head.
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072489
Glad to see you have got it fixed. Well done.
Now, call me a miserable old git, but I cannot help myself ... ... ... ...
I can ignore the "no" rather than "know", as an example of Twitter-youth mangling of our language. But the misuse of "use" , instead of "you" - for God's sake!!! It is the same number of letters, so it is no easier to type!! Just use the right word, why don't you???
Please, to save my blood pressure and be kind to the older generation, use "you" and not "use", because misuse of "use" is not useful!
Cheers. :D
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5073205
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
