hey guys
i was driving home one morning giving it a heap , i didnt notice the tempreture but when i looked down it was on H !
i was about 300m from home so i put it in 5th and cruzed very slowly. i opened the bonnet and it was pissing out steam and coolant was dripping out from the back of the motor but wasnt exactly sure where.
later on i got in there and had a look . i narrowed it down and i think i found where it is but cant get rite in there . it just under the last manifold at the back of the motor about 200mm down. ive tried to look underneath but the starter motor is in the way and i cant get the last bolt off ! and i dont want to start taking off the manifolds coz i no its a big job!!
i no that this isnt much explanation but hopefully one of use have had the same problem and use could help ????
even if use could recomend me a place to go in perth that is a specialist in the whole cooling side of the motors.
if use can help at all, it would be much appreciated!!!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/306580-big-problem/
Nice work champ :)
Try harder to get that last bolt of for the starter motor...you got one off and gave up...you were halfway there.
Manifolds aren't a massive job either, 12 bolts and some vacuum and water pipes.
Pic of side of the block...probably just busted a hose, or it's come loose:
http://img.photobucket.com/albums/v20/IIIRII/DSC00665.jpg
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067788
yeah ill give it another shot tommorrow but its a really hard place to get to. its kind of im possible to get enough leverage and force to get it off lol!!
is it possible i have cracked a manifold or anything like that ?????
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5067822
It will be either the heater hose that runs behind the engine or the rubber hose that comes off a small metal pipe that sits under the back of the intake manifold (possibly turbo water feed, can't remember).
I had the heater hose back there let go on the dyno :cool: pricks of things to change! and they're a molded hose if you really want to get picky.
Edited by bubba
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5068381
done ! i tryed for 2 nights trying to get that starter motor bolt off ! lucky my mate could do it !
it was just a small pipe under the manifold . was a prick to get into but i just made it happen ! (some how) hah
just another question . . . i couldnt of done a head gasket or something could i ??
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072084
If you're concerned about headgasket, check for oil/water out the exhaust, check radiator for oil mixing in with the water and check the sump for water mixing in with the oil.
Maybe a compression/leakdown test if you're really worried?
I've had my RB30DET pretty hot.. blew a heater hose on the road one time and also boxing day burnouts last year water temp hit 105deg (this was well off the top of the stock gauge), 110deg - get worried, 120deg - boiling coolant.. this is probably where you will start to warp the head.
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5072489
Glad to see you have got it fixed. Well done.
Now, call me a miserable old git, but I cannot help myself ... ... ... ...
I can ignore the "no" rather than "know", as an example of Twitter-youth mangling of our language. But the misuse of "use" , instead of "you" - for God's sake!!! It is the same number of letters, so it is no easier to type!! Just use the right word, why don't you???
Please, to save my blood pressure and be kind to the older generation, use "you" and not "use", because misuse of "use" is not useful!
Cheers. :D
https://www.sau.com.au/forums/topic/306580-big-problem/#findComment-5073205
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
