pretty sure Luke had a tent pole in his jeans the whole night :laugh:
Don't you talk Mister :D
Cheers luke. Don't worry craig, as soon as the vids are uploaded, links shall be posted. Lookin through the vids now, cant believe the amount of flames I was crankin!
You did awesome mate, so sorry about the ending of it all though :laugh: But yes, flames a plenty!!!
was my first night out there had a awsome time, installed the drift handbrake button that day and by the end of the night i think i got the hang of it a fair bit. def going out next month. good fun! good to see others out there giving it ago too
It was a good evening of drifting to see :laugh:
Good to catch up with a few of you lot.
I might be spectating many more of these sessions, given that the little lady and the lad were actually entertained by it! :laugh: It has the approval of the Minister for Family Entertainment. :D
Hmm, me thinks about new project the missus might approve of :ninja:
bad bad bad night for me.... very first lap of using my brand new setup... grab 4th coming onto the straight, tailshaft literlly exploded and shattered my entire driveline, 22 seperate huge gash's threw the trans tunnel.. twisted the motor threw the radiator, snapped starter motor in half, launched me from the drivers seat into the steering wheel. so so not happy.
was the blue 25/30 ceffy
So that was you on the back of the tilt tray truck the whole time? :D
Whats the plans for it now?
ohh, so that was you in the blue33.. i got a few shots of that.
what happened to the purple ceffy on the trailer? got a couple lasps then sat on the trailer for almost the rest of the night,
yeah the ceffy was a mate of mine, diff went in first session, drove back home to get other diff, got back to realise that it wouldnt go straight in as 1 was a 1.5 way and the new one was a 2 way so lots of swearing and swapping bits and they got it all good just in time for the last session.
Go Ahead - give me 10 mins and i should have a answer for you on what the jap writing is.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
    • ECUMaster is an Australian company from memory, been around a while, and seem to actually play really well on more unique engine setups. Seems to be more of them being used in the states, and they seem to support more cylinders than most others.   My opinion on stock ECU/Nistune with he AFM, is you can tune around the issue of stalling. It's still a bit of a band-aid, and not the most perfect smoothest setup, but it can make it drive able and not an absolute PITA. But you're still compromising. A vent to atmosphere BOV has the same issue as no BOV with regards to the AFM. Both make the ECU think more air is entering the engine than there really is. And I can't find any hard science/decent evidence that supports the claims all the "you MUST run a BOV of some sort of you'll blow the turbo up". About the only one some people can give of why is "lag between gear shifts", and that is only an issue when your boost source for the waste gate is pre throttle body. I ran my boost source for the TD07S off the inlet manifold. Didn't have weird boost spiking issues, didn't have boost control issues, and on a gear shift the wastegate slammed shut, which meant all exhaust gases would be keeping it going round and round and not waiting for the wastegate to shut again when I stepped off the clutch and back on the loud pedal. It came back on boost in the next gear pretty much instantly.   ECU / tune / BOV choice I think really comes down to a lot more factors than just what you've stated. And personally, especially for daily driving, recirc setup for the BOV, or no BOV. I dislike the really loud BOV when everyone is taking off from the lights etc.
    • Hey guys, as the title reads I would like the buy a S1 GTT OEM lip for my skyline. Located in Australia. Happy to drive to pick it up (interstate I don't mind)
    • All motors are consumables. This thing costs $250,000-500,000 and makes 640hp/430 KW, naturally asipirated. It has a competitive advantage in being more reliable than other cars it competes against. They rate these engines in hours before rebuilds. Are you going to out-engineer half million GT3 car manufacturers in a garage? People really need to be honest with what they are going to do, and remember that 99.9% of the people on the internet are not honest with how they use their car and what it holds up to and how much power it makes and how easy/hard it was. Anyone worrying about the block limit of anything is the kind of person that will be unable to do a single track day, for example, perhaps not even a single session. Build the kind of car you would want to have if you could never tell a single soul about it and nobody would ever know.
    • For anyone who finds this via a search  An s14 alternator connector and Silvia Fusebox/350z headlight connector can be used. Get the non pigtail version of the alternator connector so you can use 12 gauge wire for the pump.    I am using  https://ebay.us/m/ToEEmM And https://conceptzperformance.com/czp-xenonhid-headlight-connector-w-pigtails-8-pin-male-nissan-350z-03-08-z33-or-jdm-fusebox-for-silvia-s14-czp-26060-m-8pin_p_19166.php
