You got 3 weeks man, get on it! haha.
Few things I need/want sorted. On full lock my tyres were just scrubbing on the loom in the guard, luckily I pulled back in when I did otherwise could have been very interesting, might move my loom or tuck it up more in the drivers side guard so I can get some more low. Because I was running 16's on the front, massive fail but not much choice in the matter I was getting shocking understeer, fkn fail. So next time when I go out I'll hopefully have some KU31's up front on the 33-R wheels and changing my rear cradel bushes up for more slip rather then grip
What tyres you running?
215/45/17
Other then the loom issue and understeer car didn't skip a beat. Syncros on 3rd & 4th are a bit shit too, hard to jam 3rd gear mid skid when it grinds going in so might look at epic budget get the box out and replace the syncros. I'll ring round n' see what thats worth
  • 3 weeks later...
i dont ahve any pics.... but it could have been avoided quite easily imho..
in summary
cream 31 wagon came into turn one and lost rear left wheel, either loose or snapped studs....
he spun 2 or 3 times before coming to a stop halfway between turn one and two..
5 seconds later a mint 31 come into the picture at near full noise, by the time he seen the wagon had no where to go
and smacked him in the ass...
white 21 a write off for sure, cream wagon looked like a pig anyways so now it has even more ghetto rep :)
in the mine time the goons at the start line are still letting cars go, awesome communication eh
Bloke in the mint 31 should be more awear and should have slowed right down, even mid scando should have been able to bail...
I know its take your car out at own risk and blah blah blah but if I had clearly spun out and in the middle of the track and some douche came around the corner full bore I'd be f**king peaking. Mutual respect between the drivers on the track and that mutual trust. Thick headed flamin mongrels.
That's where he f**ked up, it looked like he was 100% focussed on the entry into 1 and didn't look far enough ahead.
I shoot a quick glance down to the entry to 2 just before I initiate into 1 to make sure no dickhead is dropping ringies trying to get moving again after a spin.
If the sedan driver did that he would've seen the wagon sitting there, or at least the smoke the wags pumped out as he was pirouetting to a stop, OR the other 2 or 3 cars that were taking evasive action, and could've avoided the whole ordeal.
Edited by AndrewJZX100
You roll the dice, you're playing the game. If it's your daily, prized possession, etc you probably shouldn't be drifting it
I know this Luke,
But if it could be easily avoided by the other driver being a bit more awear I would be fuming. Like f**ken hell, get off the track if you dont have that parriferal vision (spelling).
If your doing tight tandems and you spin out and collide stiff shit, but if it can be avoided and the other drive is oblivious to whats going on around him/her they shouldn't be racing either.
Point taken Wayne. Then again look at it this way. If I crash my GTR by braking just that split moment later than I usually do just to get that extra little bit of time knocked off resulting me hitting a concrete wall, flipping in the sand traps, etc. It's the same deal. It could have easily been avoided yet I was pushing. That's what it comes down to. If you can't afford/aren't willing to risk losing it all, don't play.
Simple as that.
anyways... whos gonna be out on the 14th?? i is :P
gonna be soo much better with brand new 235s on the front, opposed to hard as f**k 50% 215s lol
oh and the hydro hand break opposed to no hand break at all haha
And you also learn some things aswell
They need yellow flags to be waved into turn one so people know they need to slow down or even a yellow flashing light at night if a car is stopped on track.
Edited by DSTROY
Simple as that.
By all means smash your own car, but to collide into someone else's because you dont have peripheral vision would cut me deep.
Anywho,
I won't be out untill September'ish I reckon Craig... Whose holding a private day? I'd rather pay $220 for track time all day rather then 30 minute slots at 10 runs during that time because there is a million people attending lol - Hydro's are good fun!
the crash with the two R31's was just stupid, wagon loses a wheel and puts his foot down (people just dont get that its stupid to do a burnout after u have spun) but the R31 was at least 2 cars behind the wagon and just drove right into the smoke
the crash shouldnt have happened and someone complained to Clem about the crash and they wouldnt let anybody do tandems, was so fail
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
