ok.... i had a breath, lost my ranga temper so let me go again..
yes, i spun coming onto the strait, yes i kept my foot in it, yes i turned around the long
way, in which mad it look like i was chucking mad ringies bro.....
relax yeah? i didnt stop in the middle of the strait and chuck multiple skids just for the hell of it.
and i know im not the only one who did it, i seen ALOT of the same behaviour
when lining up for another lap.
i seem to think you were the only one doing 1 3/4's of a donut everytime you hit turn one... if you like static skids enter a burnout comp.. theres money on offer at murray bridge speedway.. there the kind of ppl who love it you dooney...
How bout you all gtfo and let it go,
Sh!t... He was a first timer out there and you know what - I would have done the same thing. I seen people like Kojie doing it too and I don't see anyone rip into him? GTFO and get off the bandwagon.
Dw craig, if it was me I would have done it to lol
Normally skids aren't a problem cos the wind blows it a way quick, Saturday night was just bad cos there was no wind which made it a bit dangerous, Turn 1 just happends to be a third gear corner and if a car was hit flat out side on someone could be badly hurt or even killed as most cars have no rollcages or harnesses.
my 2c
I paid my $10 to get in there, and I loved the skids!
well the drivers pay alot more and dont like it when lap after lap is ruined by idoits doing stupid shit, what craig R33 did was far from the worst thing i saw tho, people doing static burnouts every time they spun, people pulling out into traffic
if you spin you dont need to make a huge smoke cloud to turn the car back around
  • 1 month later...
Yep I'll be out there, pending if we can find a car trailer tomorrow my mate will be out sliding but were having heaps of trouble finding one, all cooks, servo's etc are all booked out of trailers with in reasonable distance to him.
Anyone know of any floating around that can be lent for a days hire?
We have $$$.
Thanks lads :D
Im going out for the first time im my daily 33 I think I have everything covered. Do I need gloves?
you only need long sleeves and pants/jeans made from cotton etc and a helmet that complies to Australian standards.
Thanks man, took me a bit to get use to my new setup tonight. Went from using crappy old 215's to brand new 235 Neutons and went from 3 deg of rear camber to 1 deg. The grip level is crazy compared to last time i was out and I had problems with the handbrake because of the new grip.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
