Hi guys,
I've got some heat reflective foam left over from my CAI partition that I done.
These will fit a HKS air filter in a R33 GTS-t beautifully (see pic).
I'm really not sure if they will fit any other airfilter though, but if you like I can NOT cut the hole for the airfilter.
These have a side that is angled and a top. The filter will breath from around the headlight.
These are simular to the ones sold for $90 but mine has a top as well :D
Cost is $40 and buy will have to pay postage otherwise I'll make zero money out of it :P:)
The pic is of the metal one that I made, but the reflective foam is the same design.
Whatdoyareckon?
https://www.sau.com.au/forums/topic/3066-hks-air-filter-cai-partitions/
Thejackal,
Your PM box is full. I'll have it sent off by the weekend.
The biggest difference I noticed is when your sitting at the lights for a few minutes. Without the partition the car seemed to take off pretty sluggish and would take about 20 seconds to come back to normal. This must have been because of al the hot air it was breathing.
With the partition in, the sluggishness (is that a word?) is gone and there is max power straight away. Just what you need when a WRX pulls up next to you at a red light :P:D:)
J
Originally posted by MrSnrub
Oh yeah but i have a blitz mesh airfilter so it maybe a different size?
Also is there a hole to run a pipe from the front bar up ?
Ben
Oi ben Let me know if it fits on yours, I have same filter as yours so I'll take one if it fits...
Man that's nice clean partition I ever seen
cheers
Joe
MrSnrub & PVA_Glue,
Guys I'm really not sure if the Blitz filter will fit in the partition. The HKS filters aren't very tall but are very fat (round) to increase flow.
Have a look at the pic I've attached to this reply and you can make up your own mind if the Blitz will fit or not. The pic is of the partition without the lid on. I'm just not sure cause I've never seen a Blitz filter before :P :confused:
Ben - If your worried about air flow you can do what I've done and cut a hole in the inner guard to let more air in. No crap comes through the hole. I'm sure it would be fine without the hole, but I just wanted to make sure.
BTW: the first pic is of the metal partition that I've made, and the ones that I'm getting rid of are foam backed with heat reflective foil, but are excatly the same design. Just so you know.
I can make the metal ones if you want, but they will cost around the $150 mark cause I have to buy the metal and it will take at least a few hours to make 1 :eek: :eek:
Looking at the foam I have left, I should have enough for 2 or maaaaaybeeee 3 more.
J
ok just got one installed 2day thankz skyline33 :D and interested in that cold box of yourz....is it hard 2 put on the pod filter? Also how much performance will I get out of this?
Leon.
Have you driven your car with the pod on yet? It makes a great sound hay :D
The partition is relativly easy to put on, if your handy with a spanner you'll have no problems. You'll need to take the pod off to put the partition on. And if your fussy you could take the cross over pipe off too. But the easiest way would to make a small cut at the botom of the foam partition so you can slip it around the pipe.
Then run a bead of silicon around the edge of the partition where the top sits on. This will seal it and keep it in place.
I'm not sure how much you've driven your car with the pod on, but you'll notice that if your stopped at the lights for a few minutes and then take off fast, the car will be sluggish for the first bit, this is cause it's breathing in hot air which slows the car down. Using this it will breath colder air from around the headlight.
All up it would take about 30 minutes to put in.
I can send you a few more pics if you want to check it out.
Jayson
Yepp, no problems.
Have a look here:
http://www.users.bigpond.com/jayson77/
It's funny cause I closed my Bigpond account a few months ago, but my old web site is still working !!!
BTW: Just remember that the pics are of the metal partition I made, but the foam one is the same design, just foam backed with heat reflective foil instead of metal.
J
reserver me for one ok plz? I've got my climate control, my steering wheel horn, my right door 2 be fixed and my alarm 2 be installed this week.......man what a day has it been already.,.....
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
