Hi All,
There is this company in NZ that do a good translation of Japanese user manuals and workshop manuals.
If you visit this page and enter your interest then they may decide to actually do it when there is enough requests.
http://www.jpnz.co.nz/afawcs0131171/CATID=...uctdetails.html
  • Like 1
https://www.sau.com.au/forums/topic/306603-v35-skyline-english-workshop-manual/
keep it coming guys, the more the quicker they'll consider it...
even though you may get G35 workshop manual but a translated V35 manual might be better in cases where it's specific to RHD service.
note that this is not a simple user manual explaining how to jack up car, fasten seat belt, etc,
this workshop manual will be the full blown diagram of engine / mechanical parts etc
ask those who has had a workshop manual on an older skyline generations, e.g. R32/R33/R34
it can be quite useful to those DIY work or even for your own reference.
  • Like 1
it helps however Infiniti are LHD. in most cases they are similar, with exception that the electronic wiring diagram have different colour codes, and they do not have TV Tuner.
There are also some cases where a RHD service manual can be a lot more useful particularly when working around engine bays...
  • Like 1
  • 4 weeks later...
  • 2 months later...
I have the R33 engine manual 460 pages just for the engine.
As for fake sign ups, when there is enough interest they will ask for a certain amount of deposits before the start translating the manual.
  • Like 1
  • 2 months later...
C'mon all V35 owners!!!
I am shocked that only 34 people have displayed interest in this manual, for all the little questions people have would it not be easier to look it up in a proper workshop manual than to throw the question out there and receive guestimations as your response?
The chit chat about what people are doing to their rides is great but when posed with particular problems, the best answer will come out of the manual!
  • Like 2
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
