car started to miss, mainly above 5000 rpm in first and second. So I put in some new spark plugs same as last ones NPK coppers 0.8mm from memory. It has split fire coil packs which are less than a year old....Still missing quite badly especially above 5000rpm in first....
from trawling heaps of threads on here I've read, people talking about "crank angle sensors " ....and it beening the cause of their car missing..............does my problem sound like it could have anything to do with the crank angle sensor......
a little bit of extra info on mods done ::
dejetro pfc---so no afm's
can't think of anything else that could be related, any help or words of wisdom would be appreciated
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/
I know this sounds simplistic, but check for boost leaks.
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5068097
yeah Sheriff they are NGK .8mm same as before, typo in first post... 18psi
yes rb26's have external ignitor, and have quizzed the guys at my local workshop who say if it was that it would more than likely miss right through the rev range and under load , eg 3rd & 4th on the gas ..it doesn't only 1st & 2nd above 5000rpm when reving up fast.. they think probibly crank angle sensor............I have it booked in tomorrow so hopefully they will get to the bottom of this and I will post up the result
cheers guys
stand by
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5077483
this is getting really annoying, its been missing as above for nearly two months except this morning when I went to the workshop it didn't miss a beat, they checked the odvious stuff again eg spark plug , coils etc took for a hard drive and it never missed once so they though what else can we check this is fine,,
then I pick car up and 30 minutes later its missing again, as above ????
I'm not convinced its a spark problem anymore, ( I'm starting to question everything ), now I'm worried it could be fuel which could be dangerous ......
what to look for, any easy thing to check.............fuel pump maybe
what do I do, short of just start replacing stufff like injectors, fuel pump , regulator etc and there is still the crank angle sensor??
nothing worse than an intermitent problem
got an event in a couple of weeks, need to get this sorted...............................
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5079898
if it was a fuel problem you could tell by the colour of the spark plugs. also it wouldn't really be a missfire (unless it was an injector not firing properly). if it was the fuel pump then it should get worse under high load in the higher gears as that is when the fuel pump will be working the hardest.
does the problem happen when the car is cold, or only after it has been driving around for a while? if only when hot i would start by getting a new ignitor (although since you have already replaced coils and plugs it wouldn't hurt to get a new ignitor as well).
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5080572
thanks mad
took the mechanic for a spin this morning and it missed ( hooray ) he said definately a miss not fuel..
So back in on monday to go through ignition system ( especially ignitor & crank angle sensor ) he's already checked gaps, plugs, coils..........
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5080827
ok well this isn't going help anyone...........
got car back from shop today , all they did was put new plugs in gapped to 0.065mm took for drive , car didn't miss so problem fixed...
the other plugs where new gapped to .08mm ( couple were closer to .085mm ) as before..heat range 6..
Questions ,,, does anyone else with RB26 running 18psi have to run such a small gap, thoughts on plug gaps,,,,,,,,,,,?????
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5089419
18 psi is a reasonable amount of air being forced into a small space, having a larger gap, or even a normal one can end up with the boost air blowing the spark out. lower the gap means you have a more intense spark, less likely to be blown out. iridium and platinum plugs are also sensitive to higher boost levels which is why most revert back to copper.
https://www.sau.com.au/forums/topic/306607-r33-gtr-missing/#findComment-5111360
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
