last night i took out my instrument cluster to replace the fugly blue led's i had with red ones.. anyway, i have a quick release boss kit for my steering wheel which i took off to make getting the cluster in and out easier, that left the horn button exposed as well as the ring around it which completes the 'ground' (i think) cicuit for the horn.. the 3 plugs at the back of the cluster where as usual a prick to get off and in the process the back of the cluster tapped the horn button and maybe the ring at the same time, which produced a flash and immediate constant beeping from the dash.
i got worried and wanted to see if i'd rooted anything so re-plugged the 2 i'd already taken out back in to the cluster.
long story short.. my cluster lights all work, and the fuel gauge is active, but the rev's, speedo, oil pressure, kilometre counter and the triple gauge cluster are all inactive, but they do all light up, just no actual movement.
also when the cluster is plugged in there is a constant beeping from the dash, which will only stop once i remove the centre white plug..
i think ive fried some of the circuitry in the cluster itself though visually i couldnt see evidence of this. has anyone ever had something similar happen? anybody know what it could be? the only way i can think of finding the problem, is trying another cluster to see if it works, if it does than ive fryed mine, if it doesnt work, then ive just blown a fuse somewhere, or worse the computer.
dont know if im posting in the correct thread but this seems where all the electrical questions go..
im really keen to get this fixed as id had the car apart for some time doing mechanical work and an intense interior detail, and this was the final thing to do before i could drive again. so im spewing that ive got to deal with this now.
any help is as always hugely appreciated.
cheers guys.
https://www.sau.com.au/forums/topic/306621-have-i-blown-my-instrument-cluster/
Unscrew the back of the cluster to get a better look mate, you will soon see if there was any damaged caused. It sounds like you have fried something but to what is hard to say without having a look at it.
i took off the black cover that you see in the photo. but no damage was visible..
do you mean take off the black plastic cover then completely disassemble the thing? i was thinking about it, but didnt want to make it any worse.. but seeing as its not working anyway, i might do it tonight.
Yeah mate remove the black cover and expose the circuit board the best you can to see if you have burnt/damaged any of it. Id say that you have and that's causing the "beeping" but whether or not it can be repaired is another thing.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
