Need your advice guys.
My car is currently suffering from massive over steer due to KU36s on the front, and a stiff rear sway bar. My question is, do I fix the problem (put Kumho on the rear and upgrade the front swaybar), or should I just hit the skidpan as I am? I figure the wangs will be painful (and possibly dangerous!) but the skidpan could be a lot of fun, and the Supra will be very easy to flick around hats with the current set up.
If it were a track day this would matter but it's DECA and there's only maybe 3-5 people who take it really seriously or are out to win it so don't worry about some oversteer it just means you will have more fun :ermm: If I do get to come along I'll be ditching the hektik wing and putting my crap rims with super crap 215 wan li tyres on. It'll be more fun that way!
Leave it as it is. Just sus out how the car is behaving on the back track, during the 80% run, and use your right foot to control the rear end :)
ie: to stop the ass end kicking out, if you do not want it to
Agreed
Man up and drive the damn thing.
Agreed
  • Replies 259
Pretty sure his car is a daily driver in which case the excessive oversteer might land him in a tricky situation one day...not everyone is a pro driver! You can counter it with some stiffness up front to induce some understeer, but keep in mind that this may only reduce the threshold for oversteer and not necessarily the effects of it once it occurs. The end result can still be some unpredictable snap oversteer which can be a nightmare if you're not on a skidpan. If you're not confident with it I'd be ditching the swaybar for something with slightly more flex.
If you have adjustable suspension, sometimes softening up the rear shocks and stiffening the front can help you out. Other than that, yeah, stick some grippy ass tyres on the rear.
Too late!
I've getting 275/35/18 KU36s on the rear this Monday. I have my first real track day the weekend after DECA at Sandown with Driver Dynamics so I want it all safe and sorted for then. The oversteer really is shocking though, I'm not talking slight, I'm talking massive! I even have to take roundabouts carefully.
Need to upgrade the brake pads, fluid and replace the front swaybar before Sandown too. Bloody money pit.
Too late!
Hey I'm going to Sandown that weekend too, so will prob see you there, hopefully you are looking at me through your front window and not your rear window :). I fitted QFM A1RM on the front and their HPX on the rear, plus the TRW 600F fluid so it should hopefully do OK.
Bloody Sandown I wouldn't have had to do all that work unless I was signed up for that, but I'm sure it'll be fun :(
I use the same fluid and the A1RM's all round.
If I can say anything for them it's get them up to temp before you go too deep under brakes. Once they are hot they rock but they aren't much chop cold.
They're also doing a number on my rotors but such is life :(
Edited by ActionDan
They're also doing a number on my rotors but such is life :)
chewed thru my new rotors in 30,000km. Lot of other people are having same problems with the A1RM's
To be honest after Sandown I may even go back to OEM pads for daily driving, and only fit the A1RM for track or the twisties. 15mins inconvenience to change the pads over as needed is worth it to not have wooden brakes during the working week which is when 90% of my driving is anyway.
Just turn up on the day, surely one person won't make it on the day for one reason or another. The fact you're there gets you straight in.
Otherwise you can sit in my car and give me advice!
Don't really wanna tow the car 2hrs down the highway for a maybe =\
See how the entry list is looking closer to the event.
wait til the last week and thats where you'll start moving up the list....
Well, I was running some figures last night and I might not be able to afford it anyway.
I'm in the house building phase where they deliver little but take quite a lot lol
At this stage I'm thinking Winton Sprints in early MAy might be more like it =\
Guest
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
