able to source some Rear Alloy Bush, for R32, 33, 34. Both Gts/GTR
Made in Japan
eliminate any movement in the stock bushes.
For those who dont know, the rear cradle houses the rear suspension linkages and the diff. Nissan mounts the cradle with large rubber bushes, which can flex and move under heavy load.
By removing any movement in the cradle, it will make the rear end more predictable and improve handling.
Installation is relatively straightforward : guide
JMS sell them at $250 :Oops:
$160 per set :love:
https://www.sau.com.au/forums/topic/30666-alloy-rear-cradle-spacers/
Hope you dont mind if I put in 2 c worth here Max.
For use with pineapples, you only need, or use 4.
I have this and it works quite well - as pineapples change geometry of rear cradle, but the hardmounts are used to remove the rubber parts that allow the cradle to move.
Ride harshness increase isnt really very noticeable, but the car does feel tighter when throwing it around, and traction is a bit better too.
Steve: Thats what I thought. I already have the pinnapples and just want to stop any flex in the rubber mounts of the sub frame.
Well in that case I'll be in for a set of alloy cradles Maxx.
  • 4 weeks later...
hey guys i have knocking in the rear of my 33 that even the local suspension experts cant figure out. (sounds like strut top nuts are loose) Would pineapples or the metal sleeves maybe be my answer???? By the way i have a Nismo diff which is almost a locker??
so now i am confused after reading a few of the posts,
originally i thought u remove the original bush and replace it with these alloy ones, or pineapples for that matter.
but a few posts have confused me can u confirm?
oh and these will fit an S13 right?
ok so as i understand it u use these in conjunction with urethane bushes/pineapples rite as it fills the gap even more for extra stiffness rite?? im not too sure of the idea that you completely replace your bushes with jus the aluminium ones.
can someone confirm??
