able to source some Rear Alloy Bush, for R32, 33, 34. Both Gts/GTR
Made in Japan
eliminate any movement in the stock bushes.
For those who dont know, the rear cradle houses the rear suspension linkages and the diff. Nissan mounts the cradle with large rubber bushes, which can flex and move under heavy load.
By removing any movement in the cradle, it will make the rear end more predictable and improve handling.
Installation is relatively straightforward : guide
JMS sell them at $250 :Oops:
$160 per set :love:
https://www.sau.com.au/forums/topic/30666-alloy-rear-cradle-spacers/
Hope you dont mind if I put in 2 c worth here Max.
For use with pineapples, you only need, or use 4.
I have this and it works quite well - as pineapples change geometry of rear cradle, but the hardmounts are used to remove the rubber parts that allow the cradle to move.
Ride harshness increase isnt really very noticeable, but the car does feel tighter when throwing it around, and traction is a bit better too.
Steve: Thats what I thought. I already have the pinnapples and just want to stop any flex in the rubber mounts of the sub frame.
Well in that case I'll be in for a set of alloy cradles Maxx.
  • 4 weeks later...
hey guys i have knocking in the rear of my 33 that even the local suspension experts cant figure out. (sounds like strut top nuts are loose) Would pineapples or the metal sleeves maybe be my answer???? By the way i have a Nismo diff which is almost a locker??
so now i am confused after reading a few of the posts,
originally i thought u remove the original bush and replace it with these alloy ones, or pineapples for that matter.
but a few posts have confused me can u confirm?
oh and these will fit an S13 right?
ok so as i understand it u use these in conjunction with urethane bushes/pineapples rite as it fills the gap even more for extra stiffness rite?? im not too sure of the idea that you completely replace your bushes with jus the aluminium ones.
can someone confirm??
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
