Hey guys this is more of an expression of interest.
The car is a 1999 jap spec s15
Extremely low km's - only 41000. look at the wear and tear inside and out and it matches the kms. km's are genuine!!!
Has basically every mod under the sun, all modifications have been done properly, the quality of work in the engine bay has to be seen in the flash to be appreciated. No shortcuts taken and only fitted with jap brand parts - no ebay stuff here
ENGINE:
Engine is fully forged
aftermarket cams (stage 2) - sorry dont have specs
gcg gt3076r turbo
high mount manifold. very expensive near $1000. not ebay!
TIAL 38mm external wastegate. this is basically the only part currently holding it back from making over 300rwkw, upgrade this to a 44mm gate with a retune and car will see over 300kw atw
haltech e8 ecu - no afm. has been tuned by the best. very streetable tune, starts hot/cold every time, retuns 450 - 500km tank
turbosmart e-boost - set at 18, 20 and 23psi... car very rarly sees 23psi simply because it doesnt need it.
850cc injectors
spitfire coilpacks
walbro fuel pump
full HKS exhast
hi flow cat
custom catch can
hybrid FMIC
race pulleys
plazma custom airbox, very good setup which sees pod getting fresh cold air
cushion button clutch - has never slipped once, yet very streetable
car still maintains standered 6 speed box. box is in excellent condition with top shelf oil in it. Always shifted with care, never flat changed or clutch popped. 6 speeds WILL last with this type of power as long as they are treated with respect.
HANDLING
hks coilovers - near $4k brand new
whiteline sway bars - front and rear
front strut brace
EXTERIOR:
20inch avanti rims with 90% brand name rubber, as new condition
Black smaoked tail lights
standered jap spec body kit. looks very clean, not over the top
Body on car is superb. no dings at all. paintwork is excellent condition
INTERIOR:
interior in car is 100%
dvd player
7inch lcd screen
e-boost display
These are all the mods that I can think of atm. If i think of more I will post them up
Currently the car makes 270kw. Dont have any dyno sheets sorry, but 1 ride in the car will put any doubts to rest. As mention above the only thing currently stopping it getting to over 300rwkw is the external gate which would have to be upgraded to a 44mm item. I have not done this myself as I dont see any need whatsever. Car is stupid fast as it is
This car has had $1000's of dollars spent on it. Car is hassle free, super reliable, with km's to match, basically brand new but with twice the power.
Will come with 1 years QLD rego and RWC
Looking at getting low 30's for it... if it doesn't sell, ill keep driving it - win win
also keen for a swap with an evo or 350z - not much else but
shoot me a pm or msg (0488517193) if your interested
https://www.sau.com.au/forums/topic/306699-big-hp-mint-s15/
very nice are u interested in trading it for a 570hp - 430kw at all 4s r32 GTR insane street car and still very easy to drive
have lots of pics and info if u keen
are u serious
i hope ur not serious .
no offense 2 the s15 , but u got the ultimate weapon . y would u trade it ?
https://www.sau.com.au/forums/topic/306699-big-hp-mint-s15/#findComment-5082857
  • 3 weeks later...
  • 3 weeks later...
  • 4 months later...
price drop...
$26000 ono
had this car to long and am really after something different, never drive it now cause ive bought myself a r32 slide car to thrash about it and never find myself driving the s15 basically because its to nice to thrash and have driven it for over a year now (I go though cars pretty fast lol)
thanks
https://www.sau.com.au/forums/topic/306699-big-hp-mint-s15/#findComment-5425059
  • 4 weeks later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
