Performance Parts Clearance Hks T51r Turbo Kit, Trust Sump, Arp Head Studs, Mahle Pistons, Sard Injectors, Hks & Os Giken Cam Gears!
Hi Guys,
Sadly my car will never come to fruition so im clearing out the garage
Used Performance Parts
HKS T51r-KAI Turbo Kit to suit RB26 (800ps version)
HKS exhaust Top mount manifold
HKS GT Wastegate
HKS steel exhaust gaskets
Greddy dual Intake Pipe
Custom dump/front pipe
4,000kms old, no shaft play what so ever, Inspections welcome
$3500
RB26 Ross Balancer $450
Tomei Cam Gears $200
Sard 720cc injectors with Greddy Fuel rail $915 FIRM (not seperating)
RB26 Sump with TRUST Sump extentsion welded $800
(Includes R34 GTR diff)
Venolia Pistons RB25 Good condition (needs new rings) $400
6x Stock Rb26 rods $150
GTR stock turbos $200 turbos (no manifolds)
Brand NEW
ARP Head stud kit to suit RB26 $350
Mahle 26/30 Pistons 86.5mm pistons/rings/pins $720
Gives a 8.5 Comp ratio
N1 Oil pump $400
only opened the box to look at it, never installed
HKS Timing Belt to suit RB engines $100
Genuine RB26 Nissan Gasket Kit (the one with a billion pieces) $300
1000cc Injectors Rochestor Brand comes with 14mm Top feed fuel rail $500
HKS Cam gears (New design pink duriluim, not the old ones) $350
OS Giken Cam gears $300
3x Genuine Bosch 044 Fuel pump $200each
100mm FMIC to suit GTR $300
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $40 each
Intake manifold (corrosion on radiator hose pipe) $10
Damaged Thermo Free
Power Steering bottle $10
SMIC with piping $40
Washer bottle $10
Radiator overflow bottle $10
R33 front pair of suspension (pit use) $20
Pair of indicator lights (clear) $20
R33 cat back exhaust (tiny hole in muffler and surface rust) $50
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $100
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
Edited by R32 Driver
  • Replies 42
Posted Images
Hey,
Sorry to be a pain, but do you have any pics of the individual pieces of the turbo kit? I'm thinking of going big-single.
Thanks!
Hey,
Thanks!
Ill take photos of the kit tomorrow morning, however i wont be seperating the kit :)
Thanks for posting pics. Do you know what width the dump/front pipes are? What kind of use did the turbo see in those 4000km's?
Cheers!
3.5" dump and its a dump/front pipe in 1, made out of mild steel
Unsure what the turbo saw during the 4,000kms but Its been checked by a professional workshop b4 purchasing and no shaft play at all (Inspections welcome)
Tomei Cam Gears SOLD
N1 Oil pump SOLD
HKS Timing Belt SOLD
3x 044s SOLD
1000cc Injector and rail SOLD
ARP Headstuds on HOLD
Steve
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
