Help me get my shed back in order. Need to fund a new wakeboard!
HKS VPC. Come with everything. Use this to remove your AFM's on your gtr and still run std or pfc ecu $400
Set of front guard liners and front under tray. Has front brake ducts and I won't seperate. $250 Getting very rare!
RB26DETT oil pump $80
Harmonic balancer $50
R32 GTR fuel pump in cradle $80 each. I have two of these.
Twin Turbo pipe - From turbo's to intercooler pipe $100
R32 3inch exhaust with seperate de-cat pipe. Has centre muffler, no rear muffler, just straight throught to out back $100
Standard R32gtst exhaust I used to clear epa on gtr $100
R32 GTR metal fuel cap $30
R32 GTR ABS mater cylinder $100
R32 GTR G-Sensors $100 Qty 2
All ECU's below suit std injectors and turbos
2x Mines ECU's for R32 GTR $100 each
Blitz ECU for R32 GTR $100
New R/H sill panel $100 Suit GTR/GTST
R/H tail light $30
R/H mirror $25
R33 GTR lowered rear springs for std style shocks $50 sits very nice
Tein stiff springs. Perfect for drift. $30
Melbourne Can post. Please no time wasters. You know who you are!
This will all end up on ebay if its still around in a few weeks so I thought I'd give the SAU crew first dibs.
Looking for a std boost solenoid, flywheel and clutch and intercooler for R32 GTR.
https://www.sau.com.au/forums/topic/306748-large-range-r32-gtr-gtst-parts/
  • Replies 42
De-cat pipe is to suit the exhaust. Prob won't go between a std style front pipe and exhaust. Might be a bit long. Its just a bit of pipe with 2 flanges welded on. No need for pick.
Re- clutch/flywheel. Might be interested. Depends on price. Don't need it to bad but its a bit of a pain when I have to take off with my boat on when stopped on hills or at the ramp with the tripple plate in it. Pm me with a price. It'll just mean I can't give the car to much of a hard time as I've seen a few std flywheels explode.
There for std injectors with the normal mods - exhaust and a bit of boost. I have run all of these and they run fine. Don't have any dyno results for them compared to stock but I did look at the fuel and timing map on them and it was std bottom end of map with a fair bit of timing and fuel taken out of the top where you don't want it after adding a little boost.
How much you wanna spend on clutch an flywheel as I have a exedy heavy duty cushion button clutch and STD flywheel sitting around...
Feel free to contact me On 0419797023 cheers Tim
Wouldn't spend much as a flywheel is worth nothing as there the same as 20's I think plus they explode and a clutch is only around $250 new. Pm me with what you want for it.
Got One pm replied.
There just std looking ecu's with Mines and Blitz ecu stickers on them. They're definantely chipped.
$100 is cheap man..but once they are chipped, (normally done in japan) they cannot be played with at all... had one in my GTR.... got rid of it with the engibe build... you wouldnt have front pipe for 32 GTR would ya?
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
