Large Range R32 Gtr / Gtst Parts
Help me get my shed back in order. Need to fund a new wakeboard!
HKS VPC. Come with everything. Use this to remove your AFM's on your gtr and still run std or pfc ecu $400
Set of front guard liners and front under tray. Has front brake ducts and I won't seperate. $250 Getting very rare!
RB26DETT oil pump $80
Harmonic balancer $50
R32 GTR fuel pump in cradle $80 each. I have two of these.
Twin Turbo pipe - From turbo's to intercooler pipe $100
R32 3inch exhaust with seperate de-cat pipe. Has centre muffler, no rear muffler, just straight throught to out back $100
Standard R32gtst exhaust I used to clear epa on gtr $100
R32 GTR metal fuel cap $30
R32 GTR ABS mater cylinder $100
R32 GTR G-Sensors $100 Qty 2
All ECU's below suit std injectors and turbos
2x Mines ECU's for R32 GTR $100 each
Blitz ECU for R32 GTR $100
New R/H sill panel $100 Suit GTR/GTST
R/H tail light $30
R/H mirror $25
R33 GTR lowered rear springs for std style shocks $50 sits very nice
Tein stiff springs. Perfect for drift. $30
Melbourne Can post. Please no time wasters. You know who you are!
This will all end up on ebay if its still around in a few weeks so I thought I'd give the SAU crew first dibs.
Looking for a std boost solenoid, flywheel and clutch and intercooler for R32 GTR.
  • Replies 42
De-cat pipe is to suit the exhaust. Prob won't go between a std style front pipe and exhaust. Might be a bit long. Its just a bit of pipe with 2 flanges welded on. No need for pick.
Re- clutch/flywheel. Might be interested. Depends on price. Don't need it to bad but its a bit of a pain when I have to take off with my boat on when stopped on hills or at the ramp with the tripple plate in it. Pm me with a price. It'll just mean I can't give the car to much of a hard time as I've seen a few std flywheels explode.
There for std injectors with the normal mods - exhaust and a bit of boost. I have run all of these and they run fine. Don't have any dyno results for them compared to stock but I did look at the fuel and timing map on them and it was std bottom end of map with a fair bit of timing and fuel taken out of the top where you don't want it after adding a little boost.
There just std looking ecu's with Mines and Blitz ecu stickers on them. They're definantely chipped.
$100 is cheap man..but once they are chipped, (normally done in japan) they cannot be played with at all... had one in my GTR.... got rid of it with the engibe build... you wouldnt have front pipe for 32 GTR would ya?
 Share
    • Looks like a healthy scene. You've had an R34 before?  What are your plans?
    • So here is local scene in my city, not much but we are always welcome for any foreign Nissan sport cars buddies!
    • Hey man Thank you! Excited to be here Mostly 4 doors ER, HRs not much of 2 doors, I personally know 3 guys that have coupes And yeah, they are some BNRs, BCNRs, not that much left, some of them went to EU.   Thanks, actually the conversion was done by previous owner, I wanted to get it even when it was 20DE AT cause the chassis was taken care well but getting it with MT turbo wasdefinitely an additional pleasure 😃
    • Hey guys   I'm pretty sure this question was asked before, I had an HR34 before, got another one again and I never gave much attention to this but wanted to ask you guys about dropping or pushing bonnet problem. ER, HR got pretty heavy steel bonnets, I'm sure S chassis and other R chassis gens also got heavy bonnets. I used to push it after I gently put it down on the latch but I saw some videos guys dropping it from 30-40 cm and some say it's more reliable way to make sure it's safely closed. I let it drop a couple times from like 30-40 cm and it's locked no problem but it gives me that bad OCD feeling after that that something is damaged lol, the bonnet rubbers is there, guess they handle that little fall energy well and the latch itself is what stops the bonnet right?  Talked to other Skyline owners, some say both methods are fine, some against dropping it by any means, some drop all the time no problem. So I'm like confused if I was doing it wrong or not and if I already messed up something. ...and jealous of my friend's Z, dropping aluminum bonnet feels so much right and better haha
