I bought my V35 3 months ago and I haven't really try out the speed.
I tried to step down the peddal but when is starts to reach 130km + the steering starts to "vibrate" or shakes and I am afraid to speed up further and it does not goes straight.
is it because of wheel alignment?
Edited by tonich
https://www.sau.com.au/forums/topic/306769-steering-wheel-shakes-at-high-speed/
I had the same problem actually. Completed allignment and it was still doing it.. Found out that one of the rims was buckled ( inner part of the wheel was buckled due to previous owner hit sumthn real hard like a big pot hole or wateva ) replaced wheel and it was fine..
alignment has nothing to do with shakes.. u needa balance one of ur weights might have fallen off or are not accurate i doubt your rim is buckled you would probaly know if thats the case.
130+kz on a track right? haha.
probaly cost you like $15bucks to fix.
yeah most likely requires a wheel alignment
*facepalm*
if one more person says wheel alignment im guna go nuts.
alignment has NOTHING to do with shaking its a balance. alignment will just make the car pull left/right or whatever.
if im wrong feel free to flame me.. but i doubt it.
could be wheel balance, could just be shitty tyres, could be a damaged rim, and if it stops doing it the moment you lift off then it is an engine mount
investigate this second.. happened to my dad back when he had his prelude, got wheels balanced (even an alignment as well lol, but it was tracking a bit side to side) and it still did it. brand new yoko tyres and the problem disappeared
*facepalm*
actually when I bought the car, I had MTA checked the car and they suggest wheel alignment as the car was pulling to right slightly. as with the wheels they did have some scratches and I don't think they are bent. anyway lets do both balance and alignment.
