list of some items i wish to sell: i will get a reading from the odometer asap.!
standard radiator from s2 R33 RB25DET excellent condition $150
standard s2 R33 RB25DET block no head,no fuel rail,comes with standard injectors intake manifold turbo manifold no turbo block is in very good condition, $800
standard in-tank fuel pump s2 R33 good $50
s2 R33 RB25DET auto-trans + pedals excellent condition stage 2 shift kit been serviced new filter trans-fluid etc from mike at M.V. automatics $500
s2 R33 RB25DET impul auto ecu removes speed limit cut rev limiter goes to 7.200rpm i think been awhile since i have been on the dyno give or take boost cut removed or moved i was running 1bar $200
2x standard boost solenoids $15 each
from a s2 R33 whole complete A/C shit from the engine bay ill check with my mechanic $400
call me on (0401409575 Allan) or pm-me parts can be delivered via freight/courier at your expense or pick up in adelaide parts are with my mechanic so can organise it any-time.
All prices are negotiable.!
I will be going to my mechanic on Friday so i will take some happy snaps of the parts and get the odometer reading too.
Regards.
Allan.M
Edited by R334door(s2)
Does the fuel pump include the cradle? I'd like just the pump itself with the power plug and wires, with no cradle. How much posted to Melbourne?
Edited by Anmanindustries
yeah comes with cradle bud hows $60 delivered/posted what i will do is call my mechanic as he has to install a Tomei fuel pump i will see him monday to pick it up and then post it to you straight away if you are interested.
i will need postage details pm-me when u get the chance and i will give you my acc details ok.
Regards'
Allan.M
Hey, I got your PM but I can not reply as I do not have enough posts. Can you PM me your email address.
If you are replacing the pump, you will probably need the cradle. Either way, I dont really need it (the cradle).
no probs with the tomei fuel pump these units come pre assembled with cradle,etc.
hey mate u got stock air box filter..i need one for rwc on my r34 gt-t...u know if r33 one is compatible with r34.. thanks
nah never had one bud sorry im sure there the same im just not certain that's all sorry i cant help ya out.
also
R33 radiator SOLD
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
