list of some items i wish to sell: i will get a reading from the odometer asap.!
standard radiator from s2 R33 RB25DET excellent condition $150
standard s2 R33 RB25DET block no head,no fuel rail,comes with standard injectors intake manifold turbo manifold no turbo block is in very good condition, $800
standard in-tank fuel pump s2 R33 good $50
s2 R33 RB25DET auto-trans + pedals excellent condition stage 2 shift kit been serviced new filter trans-fluid etc from mike at M.V. automatics $500
s2 R33 RB25DET impul auto ecu removes speed limit cut rev limiter goes to 7.200rpm i think been awhile since i have been on the dyno give or take boost cut removed or moved i was running 1bar $200
2x standard boost solenoids $15 each
from a s2 R33 whole complete A/C shit from the engine bay ill check with my mechanic $400
call me on (0401409575 Allan) or pm-me parts can be delivered via freight/courier at your expense or pick up in adelaide parts are with my mechanic so can organise it any-time.
All prices are negotiable.!
I will be going to my mechanic on Friday so i will take some happy snaps of the parts and get the odometer reading too.
Regards.
Allan.M
Edited by R334door(s2)
Does the fuel pump include the cradle? I'd like just the pump itself with the power plug and wires, with no cradle. How much posted to Melbourne?
Edited by Anmanindustries
yeah comes with cradle bud hows $60 delivered/posted what i will do is call my mechanic as he has to install a Tomei fuel pump i will see him monday to pick it up and then post it to you straight away if you are interested.
i will need postage details pm-me when u get the chance and i will give you my acc details ok.
Regards'
Allan.M
Hey, I got your PM but I can not reply as I do not have enough posts. Can you PM me your email address.
If you are replacing the pump, you will probably need the cradle. Either way, I dont really need it (the cradle).
no probs with the tomei fuel pump these units come pre assembled with cradle,etc.
hey mate u got stock air box filter..i need one for rwc on my r34 gt-t...u know if r33 one is compatible with r34.. thanks
nah never had one bud sorry im sure there the same im just not certain that's all sorry i cant help ya out.
also
R33 radiator SOLD
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
