No.....just the cooler.
At retail you can buy the cooler by itself or with the other fittings etc....that's why "Chaser" price is from $2200 at the moment.
Fitting, lines etc. can be brought almost anywhere.
https://www.sau.com.au/forums/topic/30680-arc-oil-cooler/#findComment-622416
It was designed to be placed where the grill is currently...ARC make a replacement grill if you don't want it out in the open for all to see. (refer Pic's above) However it was mounted behind the bonnet latch, instead of in front of it, to retain std. grill and look. Your choice and it's cheap as chips at the current price.
Thanks for the interest
Phillip
https://www.sau.com.au/forums/topic/30680-arc-oil-cooler/#findComment-623874
Phillip
still available, will you ship to the uk?
https://www.sau.com.au/forums/topic/30680-arc-oil-cooler/#findComment-624405
  • 3 weeks later...
  • 1 month later...
