What do you guys reckon of Link computers for R32s?
I know quite a few New Zealand guys use them and seem to like them.
Which would be better between a Link computer and a remap for an R32 RB20DET with FMIC, full exhaust, T04E, external gate, bigger injectors etc etc
Cheers
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/
Hi JiMiH, my choice would be to remap in real time the standard R32GTST ECU, if you have finished your mods. If you still have things to upgrade, then a Power FC would be a better choice as the extra cost would be covered by the saved chip burning.
Hope that helps
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-622820
i went to get info on the new wolf 3D for my rb20det and the bloke said that there was nothing better than the link ECU for a rb20det and then he told me it would be $2300 fitted and tuned so i tuned out, am now looking to remap the factory ecu to get my end results for a thrid the cost!
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-623975
How does the Wolf compare to remapping the stock ECU then?
I mean apart from the "wanky" features that you can get such as rotational idle, are there benefits of a Wolf3D above a remapped ECU?
I haven't finished my mods yet, but I think once you have a remapped ECU you only pay for dyno time later to retune it?
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-626337
James,
I took the remap route and all is sweet at the moment. The place that did my tuning, as you know, are able to do pretty much anything with the ecu, except for the features as you mentioned. They can also do a few other really cool things with the ecu as well. Bit hard to explain on here but they can put on "Valet" mode etc. Stops dickheads thrashing your car basically.
A whole lot cheaper than a Link I'd imagine.
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627774
I know enough about the Link not to suggest anyone uses them:p
JiMiH, The wolf will provide so many more features over the remap, without getting into the wanky stuff like anit-lag rotational idle etc. Pop down to see Steve at SST he'll be more than happy to run through some of the feature and demo the software to you:D
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627808
Yeah I spoke to Steve at the drags the other night and told him I'd pop in one Saturday morning to check it out.
Dan, I'll have to have a chat with you soon mate and you can tell me bout your remap :( Not to mention take me for a drive :(
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-627817
Traction control is wanky stuff:p The traction control works via hall-effect sensors, and sends a signal to the engine to drop the power, rather than a second butterfly infront of the plenum like the factory fitment traction controls use. Not much good on turbo engines as it lets the turbo fall off boost.
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-629393
save a dozen maps on your pc
give the bagging a rest, RIPS times are a recommendation for the stuff and ive seen 100's of cars run link with awesome results and no problems. objective debate might be better to base a decision on but is sometimes a little difficult for some
pm me jimih i can help you out with heaps of cars running it but a remap would be cheaper and just as effective as an aftermarket ecu
https://www.sau.com.au/forums/topic/30683-r32-link-or-remap/#findComment-630526
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
