Hey guys just pulled out my fuel pump and found to be stock, so will be upgrading soon.
Also decided to check voltage supply to pump as i've noticed few complaints (mainly r32) of voltage drop under load.
Battery voltage varied between 13.3v - 13v
Fuel pump voltage sat around 12.9 - 13v at idle and cruising, but dropped as far as 12.6v when I planted my foot into it.
Anybody reckon this is cause any probs for pump? or should I just direct feed it to battery anyway.
Also looking at Nismo, Tomei or HKS fuel pump. Is there actaully any difference between them. All around the same price.
Cheers :happy:
https://www.sau.com.au/forums/topic/306832-r33-gtr-fuel-pump-voltage-drop/
Cheers :happy:
Don't waste your money, get a Bosch 044 and mount it in tank with a relay so it gets full battery voltage. Look in DIY section.
Nothing a bit of insertion rubber and a couple of hose clamps can't fix!
Yeah true but I reckon fuel surge would be a fair bit worse with that sort of setup. I guess if you dont track it its not a problem.
Hi. I had a similar problem in my gtr whilst getting it tuned. There is a fuel pump speed controller in some models of the 33, to bypass it, run a ground/negative wire from the pump directly to the chassis/battery. remember, ONLY do the negative as this is what controls the pump speed. Its a 5 min excercise and if it is the fix you were after, then choice. If its not, then hey, 5 mins and 40cm of wire is bugger all right?
Cheers, Allan
yes it is the fuel pump voltage regulator. It keys off the ECU, and varies the pump voltage according to engine load.
Unfortunately it is not able to drive the pump at full load without caving in (which is seen by a big dump in voltage).
So instead of wasting money on a new pump, just wire it to negative and you'll hear it is louder at idle, and you're also recirculating a lot more fuel back into your tank too, which might lead to fuel heating issues if your tank is nearly empty and you are in heavy traffic on a hot day.
but it solves the problem.
my advice is get the nismo pump. they are direct bolt in and work very well and very reliably. I have not seen one problem or failure of one EVER. I have seen a number of bosch pump failures though and others that did not live up to their flow claims. as best I can tell the nismo/tomei/HKS pumps are all the same so chose which ever one you can get quicker or cheaper.
adding a direct feed from battery to the pump (with a relay) is a good idea too. regardless of which pump you get.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
