  • Replies 109
Posted Images
Thought I'd throw up a few of the shots I've been learning to do :P Comments welcome!
Taken on the southside of the gateway at the park nearby. Was messing with new flash and using car headlights. I really like the surreal lighting on the leaves.
Northside of the gateway under the new section. Messing with long exposures, this was taken at about 9pm, pretty much pitch black, but with the passing traffic and traffic lights gave some interesting lighting.
Other direction of the photo above, again, messing with exposures and lighting
Hows this one?
Yeah nice!
Might be slightly underexposed and framing slightly to the left (to get more sea in so the chair is at the right hand third line) might have helped (IMO)
Can't change framing now but for exposure this is kinda what I mean:
Good shots man. As for last shot - did you de-saturate one person and leave the other one saturated? Looks a little strange..
Haha I forgot about that. Yeah I did because she really ruined the pic imo. I probably should have de-sat the other person too. :sick:
Here's the original. :)
Couple from the trip to springbrook.
Possums were crazy. one tried to drink my beer. Others would let you pet them. A couple had a fight and ran straight towards me. I had to jump over one of them haha.
I dont knokw if i like the PP on the first two. I dont even know where to start or what look i want to finish with. too many possibilities.
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
