i didn't know where else to post this as its not really general maintenance, but as the title says, i got a problem with my air con! it's an R34 GTT
what was originally happening was the complete opposite, i had super cold air on 18 degrees, then anywhere from 18.5 - 32, would be super hot, like instant jump from actual 18 degrees to actual 32 degrees even on '18.5'
and i had my dash cluster out the other day replacing a backlight, and noticed that the little plug and hose that connects to the spot behind the facia that detects the inside-car temperature had always been unplugged since i bought it, so i plugged it back in thinking YES i found something wrong and fixed it, anyway, gave it a test, and now it's doing the complete opposite, it's complete coldness all teh way through the temperature range from 18 to 31.5, and at 32 its super hot.
whats the go here?
would there be another sensor somewhere not plugged in causing this like the in-car temp one was? or something else?
thanks for any help,
Brad.
https://www.sau.com.au/forums/topic/306852-air-con-problem-on-r34-gtt/
hahaha, sorry i just found that funny
at least you didnt short circuit your cluster like i did.
regarding your actual problem im unaware of any other sensors, i think the one you plugged in was the only one, it may be your actual climate control unit playing up. if you have access to a mates unit, swap them out to see if it is a faulty unit or not.
otherwise i cant think of much else.
cheers
Edited by BXAFTW
mine does the same man... i cant remember how but some guy in brisbane here who specialises in skylines performance etc fixed his and i asked him to fix mine.. he did say wat it was but i cant remember.. sorry mate but it is only a sensor stuffin up in behind there
  • 2 months later...
  • 1 month later...
probably your cabin temp sensor unplugged, that was my problem and now all is well.
follow these instructions to figure out what sensors are failing
http://www.skylinesaustralia.com/forums/Ai...p;hl=diagnostic
remember the sun sensor will register as failed at night.
r34's do not have hot and cold buttons, instead slowly turn the climate control dial from left to right to enter the different diagnostic modes. the mode you want is about an 8th to a quarter turn i think, and it'll flash the appropriate numbers.
if it flashes 22, then your inside cabin temp sensor is not working. it is often left unplugged after work is done in the drivers side foot well. the sensor is behind a plastic grate on the left side of the steering wheel. to get at it do a search in diy, but from memory there's about 6 bolts to find to get the large bit of plastic off from under the steering wheel, then lower the steering wheel as far as it'll go and take the plastic off from around the speedo etc, then its a white plug just behind the grate.
good luck mate
ey mate,
that did it.
i've been driving around with cluster perspex cover off (and that plastic surround covering it) because i'm replacing the cover soon and didn't want to bother with the hassle of taking off everything.
thanks
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
