Ok ever since i have brought the car there has been a problem with the battery the guy i brought it off also said he had issues with it. :D:(
I know its not the alternator cause i have had the raa check that and the said its charging.
So i have decide that im going to buy a new car battery and was wondering what everyone else is using in there Stagea. This will also need to be powerful enough to run my subs that i will be putting in the car as well. :P
Cheers
https://www.sau.com.au/forums/topic/306871-car-battery/
I've got a battery from RAA. A 7232 battery if I remember correctly.
No problems as yet. Had it for about a year.
Starts the car with very little turning over after over a week of no use. No probs.
When I'm at work tomorrow, I can confirm battery code and battery price for you if you want.
Of course, it comes with a 2 year 24/7 roadside warranty as well :D
https://www.sau.com.au/forums/topic/306871-car-battery/#findComment-5071608
I just fitted one of these into my M35 Century Battery
Under AUD 100 from Bursons.
Fitted the higher CCA and longer warranty one in my old R33 GTS-t, but that was not in stock at Bursons, and was AUD 40 more expensive in Super Cheap so went with the 2 year warranty one.
https://www.sau.com.au/forums/topic/306871-car-battery/#findComment-5073087
I'm running an odessy dry cell in my s2, smaller slim line type, not sure about code but can get it if anyone wants it.
Originally brought in 2004, had it in my s15 for about 10 months, before installing some subs etc. i Dont recommend using one of these smaller dry cells if you are planning on big sound systems, unless you run another battery in series in another location for the sound system. Battery had been sitting in the shed until about 2 months ago when i put it on trickle charge for 3 days and then put it in the stag, fantastic fit aswell (ill get some pics). Started first hit no problems and has been going strong ever since...
https://www.sau.com.au/forums/topic/306871-car-battery/#findComment-5079294
Don't forget you have to wrap the handles in foil... Shinny side out it will not other wise...
sorry its shin on the out side on the pos and shiny on the inside for the neg, cos the 'lecticity flows from pos to neg
i also use diet coke cos its more acidic :)
https://www.sau.com.au/forums/topic/306871-car-battery/#findComment-5080316
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
