hey all i have a series 1 r33 gts-t, it has the stock front bumper on it but just wondering if the clear lights down near the indicators are fog lamps, theres a relay spot under the hood where some fuses etc are but i cant seem to find one to fit in the shops.. any ideas where i could get one from so i can get these lights goin, i have a PIAA switch on the dash im pretty sure its to turn them on/off
thanks
https://www.sau.com.au/forums/topic/306883-r33-series-1-fog-lamps/
  • 3 weeks later...
  • 2 years later...
the stalk will bolt on. you will also need a relay. im not sure if there is a loom running down to the lights though. its probably taped up so somewhere there is also an additional plug that needs to be pluged in at the stalk
there is a spot for the relay and im pretty sure there is a loom to the switch. cant be sure on a loom to the lights i would think there would be though. have a look around the area for a plug that isnt connected
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
