My dump gasket has gone and 4 of the bolts have vibrated off, so I thought Id put a split dump pipe on
The turbine outlet is quite smaller as it is split,   This will obviously bring boost on faster but sacrificing top end flow
I believe they split them to stop the pulsing of the gases out of wastegate interrupting the flow of the turbine outlet
Are they a worthwile upgrade, or only for response and midrange
https://www.sau.com.au/forums/topic/306907-split-dump-pipe-opinions-wanted/
i dont believe there is any response gain by using a split dump
when the gate is closed, it is closed and nothing comes out, so the size is irrelevant
its only relevant when the gate is open
the split dump reduces the turbulance by ensuring they each have their own seperate paths
having the turbocharger outlet hole going into the size of the split dump dump (if that makes sense) or runnign to a 3" bell mouth, i dont believe there would be any different in response
they both must travel through the smallest common denominator, which is the exhaust wheel outlet first
Whenever u change the size of a pipe,
bigger pipe=more flow at top end and reduced flow(air speed) down low.
smaller pipe= increased flow at low rpm  while being restrictive in the top end.
3 inch pipe will flow say 500hp.
Where two 1.5 inch pipes will flow 500hp will alot faster air speed and alot better response
^ I don't know where you get your advice from mate, but it's horribly incorrect.
Bigger pipe down NOT reduce down low torque. Infact it increases it by allowing the gases/air to move around more freely - so long as the motor is tuned accordinly of course.
So putting a bigger exhaust on ur car will have the same response as stock,    Not a chance
So ur saying a bigger pipes air speed velocity at low rpm is the same as a smaller sized pipe.   Not a chance
The smaller the pipe, the greater the air speed velocity will be, until it gets restrictive, where it robs u of top end
Edited by Dorifta
You're first post is wrong, as Paul has stated.
Have a look @ the turbine inlet housing, then perhaps you might appreciate what happens after the turbine wheels doesn't mean a whole lot in the situation you are talking about here.
The sheer fact of the matter is, you are not right. My own car is a testament to this.
Having gone from large, 2.5" twin aftermarket dumps, BACK to factory, with exact same results. It was if i never changed parts.
Not only is my own car a great example, but the 1,000's of other cars on this forum as well.
If you think you need backpressure in the exhaust to make low end power/torque... then i'm throwing in the towel before this goes any further.
So whatever you reckon mate - i'm not going to argue with you if you think you are right as i have proof, you have a theory.
N/A cars don't need it either. Issue is the same there as i said earlier.
People put exhausts on, and don't have the car retuned.
So the N/A feels sluggish all of a sudden as the car is setup/tuned for emissions and straw sized exhausts.
One thing is for sure the bigger the dump pipe and exhaust on a turbo car the better. Less restriction means turbo spools up quicker increasing response, decreasing lag and also increases top end. Its better in every way.
I have heard of people putting larger exhausts on an N/A car and saying they lost a bit of down low torque but gained mid range and top end. Although I am no expert on that so will leave it there.
As said by paulr33, the split dump will not help with response but will help top end flow. How much I do not know. Surely someone has done a back to back dyno.
Edited by Harey
1. To present the greatest difference in pressure across the turbos' turbine (to make it work the best), you want to have zero backpressure after the turbine. Bigger is usually better, but you also want to limit changes in cross sectional area.
2. Split dumps should help when the wastegate is closed as well, due to their ability to limit turbulence just downstream of the turbo. Turbulence = backpressure.
3. Split dumps are much more sensitive to sizing than bellmouths. With Bellmouths you can pretty much bolt any dump to any turbo and it should work fine. With splits you need to take some care.
^^ that's all theory. Reality may be different.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
