Can anyone point me in the right direction of a good website to view some options for a boot spoiler on my car? I'm in NZ, but Oz/Nz site would be great.
Thanks Again!!!
It's not a good one but.... www.carmate.com.au
Hi garry nice to see a fellow nzer on here:) i have the stock optional spoiler which suits nicely
Hi Drunken,
Where did you order this from?
Had a great day yesterday...Got invited to a private meeting at Meremere Drag Strip! There was a lot of serious racers, but there was also Beetles, A3's/A4's & older Skylines, etc...so after a while I gave it a go...best time was 16.1 secs for the 1/4 mile....certainly not the fastest, but great fun......
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
