TBH i think my problem will be a massive lack of traction. Having so much torque down low will really make it hard to go anywhere.
I've been trowling through BMW forums and there are quite a number of them with these s/c's on them only running around 300-350hp (on about 9psi), not sure if thats at the wheels or engine and they claim to have alot of trouble with traction as the onset of power is just so brutally hard and fast. They are running a smaller unit then the 2.1L I've got also. They also mention that the power is so linear and easily controlled with the right foot once youve adjusted to it.
Im quite excited about this!
Back on the bracket, I buggered up the original one when I went to put it back together last night with the new mods. So the new front face plate will now be made out of a 30mm billet block of steel on the CNC mill and have the spacer bushes incorporated into it :no:
perhaps you will have to invest in one of the larger 2.8l models for the race car :(
lol yeh that is a very cool thought. It has crossed my mind and did infact when i was deciding which one to get for my road car. But they told me to go for the 2.1L first and that I would be very pleased with it. Time will tell!
Got the new bracket assembled on the weekend and its all good! Finally got past that issue now. Been fiddling with intercooler, radiator and accusump fitment in the front end tonight. Didnt take any pictures as its not all complete, but it all fits together pretty well. However if I had retained the air conditioning the accusump would definitely not fit in the spot between a/c core and intercooler. But after this bit is done then its onto the new 3" intercooler piping!
Decided Im pretty well going to paint everything flat black so it just all blends in. I dont want anything standing out, so no blingy chrome bits anywhere for potential cops to look at "IF" I get pulled up in the future. Plus the whole stealth look is always great.
Got a few pics of the new speedcar too which finally turned up and is taking up my spot in the shed. My car is now back outside...so annoying. I think they are trying to get it ready to run for this saturday night, if anyone here follows snorway.
Edited by r33_racer
Been abit slow lately. But I did start on the i/c piping and have about half of it done, hopefully get the rest of it done tonight or pretty close.
Crank pulley got finished today also and it looks fantastic! Bolts up where the powersteering pump pulley was.
I am using a Ross Tuffbond Metal Jacket balancer too. Much more affordable then the ATI units.
Hopefully I will have more photos soon showing the supercharger bolted up with piping connected and things starting to take shape :D
Yes it will be interesting, lol you are dead on. Intake is a big 180 degree oval about the same shape and size as the back of the supercharger. Its going to be quite tricky as the first three cylinders will run right into it :P
Having an rb30 instead would make it alot easier as the extra 40mm in height would help tremendously with the exhaust side of things.
Figure I might throw up some pictures from last night to show how its all sitting atm.
The bracket behind the intercooler is the new bonnet catch support which also holds the accusump. The accusumps bolts line up with the extra two brackets I tigged onto the i/c to tie it all together for added rigidity.
I have next week off work to try and slam out as much as I can on this project, may need two weeks to get most of it done though. Starting to get excited as its getting closer and closer and feeling as if its actually all possible and maybe going to work.
Lol I had also thought about (jokingly ofcourse) the short pipes idea. Ahhh if only! But hopefully there will be enough room to run those first three cylinders straight up near the cam covers and then back down to the collector/s.
Tonights effort I got the drivers side completely finished in terms of i/c piping. Got about half of the p.side done so far, wont have pics until its all done. It will take longer as im going to make one of those afm into i/c piping mojos using a q45, which will hopefully work out and I gotta put the bypass valve in there somewhere too, along with my overboost valve.
Anyway a couple of pics :)
i have always thought how bad ass it would be to supercharge my R33 GTS25T so i cant wait to see how it all goes ;):)
also 20psi at 2000rpm imagine that as a daily driver. it will go :D
note* u should try and sell this build story to a car mag or something who knows u could recoup some funds
Im hoping to get this into a car mag when its all done. I doubt ill get paid for it though. Fingers crossed!
I havent actually finished the accusump install yet. Ive only fabricated the bracketry to hold it in place. Once I get upto that part Ill show/explain what I plan to do.
So ive only got a few pics of bits and pieces that have been fabbed/machined up. The rest of the i/c piping is done, but I realised I can't do the bypass valve yet until I make the intake so I can locate accordingly. I ran out of argon this afternoon so my efforts got cut short. I was about to start the intake too! Im waiting for my boost relief valve to arrive from gcg. Should get it tomorrow. Hopefully by sometime early next week Ill have all of the ally fab work finished! Then it will be time to start the biggest PITA bit of this project. The super duper intricate headers....Then once thats done it will be the rest of the new exhaust system. I have two Borla XR-1 Multicore racing mufflers enroute from summit. The Borla rep reckons two of those mufflers will keep it quiet without disturbing flow at all.
So the goal atm is within the next week or two to have the better part of this project done so I can get to pulling the motor out, checking my bearings, oil pump, thinking about modifying my sump for greater capacity with some basic baffles, fitting the old NPC twin plate off the race car, making new billet fuel rail to suit new 1000cc injectors ive got coming from the states, fabricate a surge tank and mount for the twin 044s and then fitting everything back up to see if it will all work! Then off for tuning at Mercury!
lol just reading that, ive realised there is still alot to do! :P Everyday when I drive home from work, I imagine what it would be like if I was driving my newly supercharged skyline home instead of the turbo diesel hilux. *sigh*
Anyway some pics...
I have to give a big thank you to Kyle @ 6BOOST too for supplying me with one of his exhaust header flanges. He saved me a shitload of time not having to measure,draw and mill out my own one. Cheers mate!
Edited by r33_racer
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
    • Very cool, see what I did there? 🥲 Wild WMI setup, first I've seen where it's on each cylinder runner, usually I see a single jet pre throttle.
