Well actually ive been working on the 4" exhaust since yesterday morning. Upto the last bit under the sway bar and upto the rear muffler! Then I can drop it all and tig it all up.
Ill put some pics up soon of what ive made so far.
for 4" thats pretty tucked, nice work.
hard mounted to the gearbox hence the need for the flex joint?
Yeh its come up pretty good so far, alot higher then I imagined it would be, however when I let one of the zip ties goes holding it in place just before the first muffler, that may all change abit.
Im still using the factory rubber bracket off the gbox, you just cant see it too well in the pictures. Flex pipe is just added security I guess.
lol, IF IT kisses any speed bumps. Im considering bumping the ride height up a little bit too, as the tires scrub out sometimes. Maybe another 15mm rise in height will help prevent that from happening.
No I didnt actually, but thats a pretty good idea incase that becomes an issue. The last muffler didnt catch there, but that was only 3". There is a good chance it may happen now with this 4" system. I will look at that tonight!
as my brother just mentioned it to me earler, it may pay to do a similar thing to the flex bellows except like a heat shield so you dont catch and tear holes in it.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
