Can you put a one way valve on there to avoid exhaust getting into the system?
Yeh I have a hydraulic one way valve im going to use. I just need to modify the spring so its weaker and easily opened as this one has a 0.5 bar cracking pressure. But the rest of it is heavy duty and about the right size.
I finished the breather can last night. It was a mission to put together and weld up.
Also milled the supercharger inlet bracket flat as it had warped from the welding.
There is the one way valve im going to use for the exhaust evac setup.
I got the motor/gbox out on saturday and the block stripped by late afternoon. I cleaned the block up a little and started abit of deburring of edges and cast marks and general loose crap. I picked it back up sunday after shipping the block, head and manifolds to work. More tools, more die grinders and burrs and most importantly more air supply! After about 6 hours of grinding the block ended up looing like this.
You will be suprised at how much casting shit is left in there attached in hard to reach or see places. Main spots I noticed were under the webs where they meet the sump rails and underneath the rails themselves. If you are building your motor, take to it with a die grinder and clean that up. I was quite shocked at just how big some of these flakes were and how loosely they were attached to the block.
Today I picked up a port and polishing kit from down the road. Cost me about 160bux, but it has a heap cartridge rolls, mandrels, extensions, rotary stones and buffs which is pretty well everything you need aside from some carbide burrs. I started after work with some basic port matching of the manifolds to their respective gaskets. While at it I got carried away and cleaned up the runners of the inlet manifold using my new tool set, 40 grit cartridge roll and extension. Took a while but it looks a hell of a lot better then the cast finish and its clean again. I also cleaned up the manifold entry behind the throttle body opening.
It went from looking like this
to something like this
That is pretty well it so far. Tomorrow will no doubt be more of the same! Its fun playing with new stuff.
I love doing stuff like that, but working with old cast iron heads, kills my equipment real quick :(
Really need a good quality Air die grinder.
You changing much with the engine or is it just a quick freshen up?
Yeh, anything ferrous kills equipment unfortunately. Sucks! Great thing about alloys, shit barely wears out at all. Carbide burrs last for almost forever.
Lol, funny you should ask, as Im changing abit actually. Doing the oil control mods properly, block restrictor for head, o ringing block and head if I can fit it in, getting the tunnel honed, bore torque plate honed, crank ground .010" under, some oiling system mods and I think thats it. Probably get piston tops and skirts coated as well.
Also decided to do the rest of the exhaust system in 4" to stop these nightmares im constantly getting of too much back pressure. Probs get that just jap cooling pro 100mm gtr cooler to replace my shitty damaged pwr 75mm gtr cooler.
The more I think about stuff, the worse this all gets!
looking awesome
will you blue print also or thats what gasket matching is
Im not sure I follow what you mean by blue print? The engine during assembly/machining or the head/manifolds?
Gasket matching/ port matching is just some light grinding to make manifold ports and gaskets aligned perfectly (or as close too) and then usually doing the head ports to suit as well. Normally you only match the inlet side so there is no restriction when air is trying to enter the motor. On the exhaust however, you want the gasket and manifold bigger then the exhaust port so any reversion will hit the edge around the port and do a u banger instead of trying to go back down the port and into the chamber. So ive matched my exhaust manifold to gasket and they are both bigger then my head exhaust port which I will leave factory size for that reason.
Hopefully that makes sense.
Sounds good and is also why im leaving the Soarer alone haha.
lol. Farkk, I could have gotten that instead. Ah well. If mine doesnt work I will get that kit instead!
moroso evac fitting kit:
http://www.summitrac...arts/MOR-25900/
I'm putting on into my gts-t as we speak- h aha ha.
Are you putting your 'slash cut' fitting in the center of the pipe? I wasn't going to put it in that far, maybe 10mm in or so. I'm more worried about restriction than maximum velocity for vacumme.
J.
Lol yeh I did, I put it right after a reducer 4" -> 3" 45 cut in the centre. Thats how I was taught to do it as the best setup for maximum vacuum. Hopefully it wont be too much of a restriction.
So I finished my backyard porting job. Pretty well just cleaned up the ports and matched the inlet side. Polished the chambers lightly and roughed up the inlet with 40 grit. Did exhaust in 80 grit.
I have to admit, it took most of the week doing all that. It gets painful around the guides!
Did you read up on porting? Apparently there is an art to doing it properly. I'd be too scared to do it wrong and have worse results.
Yeh I did some reading and looked at what pictures I could find around the place to give me an idea on what to do. I didnt go reshaping ports or anything like that. I just matched the inlet manifold and head to gasket and just cleaned up the casting and machining marks. So all ive done is a clean up essentially. If you go and start opening up port sizes and messing with the shape then you could easily go backwards. But I cant really see any harm in what ive done.
But I will find out when its all going lol.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
