So Dunc, did you see the picture of my electric hydraulic power steering pump?
Yeh, I know you are jealous :P Cost me $350 aus delivered from the U.S. I got incredibly lucky on ebay, beginners luck you could say.
Would you believe that no wreckers in this country that I could find had one. Brand new from Toyota was about $1400 from Japan. You can get brand new Mercedez Benz units for $1100 from the U.S.
Once I figure the mounting and wiring of it Ill post it up in here and in the electric power steering thread. Looks like Im going to mount in the passenger side corner near the windscreen wiper motor. First hand held mock up on saturday makes it look like a promising spot.
Saturday I was able to move my car into the shed next to the race car. Continued stripping stuff out and measuring some more. Its all changed again!
Ok so I pulled all the aircon out and old manifold/turbo setup. I can now use half the power steering and half the aircon bracket holes to put my mounting plate on. Its even easier now and I can lay the supercharger down horizontally, which means I can just use the oil bath tank in the front and not worry about running a feed and drain to the motor as per my original ideas.
New bracket revision.
Assuming ive got it sorted properly, I can send these off to get laser cut this week and then start welding them up! :P I will have braces across the top and bottom areas which I will just hand make and add in when putting it all together.
Hopefully next update will actually be the bracket being put together.
Finished drawing up the rest of the flanges and bits. Hopefully get them made this week inhouse on the CNC mill instead of getting them laser cut. Mill has become free, so im going to try and sneak in my stuff before actual paying jobs come through...
Just some more 3D models of the parts to be machined.
The inlet manifold flange will have, though not drawn atm, a taper across its depth that transitions from 72mm to 82mm to match up with the opening size in the greddy plenum where the throttle body usually bolts upto. The 72mm size to take a 3" pipe ontop which will be attached to i/c piping.
The discharge port flange will have a similiar thing done also, except it will transition from its triangularish shape to a 3" round hole over its depth so I can tig on a 3" pipe.
The supercharger inlet flange will basically have an oval section linking it to the new throttle body, hopefully maintaing the same size and shape from flange to throttle body flange so it doesnt restrict airfow to the charger.
Fingers crossed, by the end of the week ill have a working bracket that *might* hold the supercharger next to the block!
Edited by r33_racer
BAM! Got two done today!
Hopefully knock over the rest tomorrow! Those two came out about ten times better then I had pictured.
Awesome Mike. cant wait to see the finished result. Will you be working on it over the weekend?
... ha haha, oh yeah- just knocked em out.
Nice one. Quality parts- if that's any indication, this SC install is going fantastic.
I think evryone has to keep a lathe, mill and cnc lazer cutter in they're shed!!!
Keep it up,
Justin.
The last two major pieces done today along with a few other small things which I didnt take pictures of yet.
The steel one is the front face plate, and the trick looking one is the inlet to the supercharger :D
Edited by r33_racer
So after the weekends effort I got the bracket tacked together and it succesfully holds the supercharger nice and square to the block and looks pretty tough. However the intake to the supercharger will run into the engine mount. So now the blockside bracket needs to be re drilled to lift it all up about 10mm which should help clear the engine mount issue. That and the supercharger was only sitting above the chassis rail by a couple of mm.
Yesterday i had to run to work and back about 3 times before I could actually assemble the bracket, but due to my old mans welding helmet being broke I ended up doing it today as I had to go back to work and get my helmet. There was so much mucking around I nearly went insane. First few times I had to mill down the main front plate as it was too thick and then make a shelf/brace which links the front plate and block bracket together and acts as a shelf for the charger to rest on so it takes alot of the weight off the front bolts. Also had to go back twice to mill down the length of the blockside bracket as it was going to run into the belt. Finally after it all goes together nicely I now have to pull it apart to change it :thumbsup:
It takes a long time to get anywhere with custom stuff, especially by yourself. I was expecting to have the bracket fully finished on saturday.
What pipes are you gonna run off the head? kinda hard to see in the pics if there is enough room to run and off the shelf set of headers to fit...or will you make your own? (please say yes, i have yet to see a well designed set of headers for a skyline)
Looking the goods though....I wish i had the gear to do this :P
good work, and keep up the updates. I remember some earlier pics of the machines in your "other" shed and you are damn lucky to have so much custom fab stuff available....I bet they are invaluable for this job.
BTW very off topic...but are you racing the rb30 again this season?
He better be Duncan, I want to kick his arse. :P
Yeh will definitely have to fabricate a set of headers, though I dont know if they will be well designed as ive never made a set before, but ill be doing my research before I start. I should have taken some more shots showing just how little space there is left around the thing. But im thinking 2" primaries, with 2 x 3into1 collectors which go to 2.5" and then merge into a 3" which will then goto atleast a resonator and muffler and then probably another muffler where my cannon is now. Im expecting this thing to be quite loud and I want it to be sleeper quiet.
Yeh Duncan the other shed is actually the family business. Which is where I keep going to either use machines or raid material I need or get stuff made on the CNC's. It is very handy to have these machines available.
Yeh we will be racing the rb30 this season. We had a practice run at lakeside the other week, actually my old man ran it cause he likes lakeside. Seems to be a trend, old people and lakeside. Anyway in this motor we've put in total seal gapless rings. Whats happening, or so we are speculating is that the increased ring seal (which is netting us 170psi comp and 2% leakdown) at idle is increasing vacuum and its pulling oil down around the valve guides/seals or our other theory which to me seems more sound is that the ring end gaps on the second and third ring are way too loose(2nd =0.032" 3rd =0.038") and they arent doing their job properly. Basically at idle its burning alot of oil but as soon as its under load, she clears right up and is sweet until its back at idle. So we are pulling it out and down and changing over valve guides to new ones weve just made from phosphorous bronze and new stem seals and putting the std second and third rings that came with the pistons back on them. Then go racing with Noel :D
hangin out for this! :laugh:
People have SAID they were going to do it, but these people were all people without an idea in their head.
Now i wonder if that could possibly be somebody else who is a regular on this forum ....? :)
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
