Cool. Well it seems like the logical way to go to try and maximise power while trying to keep the boost to a slightly sensible level. Otherwise I will have to run the car on straight methanol to take advantage of the super high boost and not have detonation issues! lol.
You should move here now....its starting to warm up quite rapidly. QLD likes to skip spring and go straight to summer!
hahah So did Canberra...went from 5 deg C to 28 overnight
Methanol would be fun then add a splash of Nitro Methane....you know about 15% and have some fun with 60psi lol
I am drooling at that thought right now......You know my uncle has a couple of drums of methanol in his shed.....the 99.9% pure elf racing indy grade stuff!
Just need to fab up a 200litre tank so I can make it to the shops and back!
Quickly worked out the numbers. 60psi would be piss easy to achieve, 0.7bar from the charger and 2 bar from the turbo. Boom 4.1bar = 60.27psi
Hey mikey have i told you that there is no nissan engine which has survived longer than 6 seconds with that kind of boost levels.
there was a Hyundai excel drag car that used to run 86psi and rev to something like 10k
they would usually last a few races and then crack the bores and they would just replace it with another stock block, pretty funny.
lol ah it is funny. The hyundai is hilarious!
If I listened to the old man Mike, I would be leaving oil restrictors out of the block! Hey dad????
Whats that senile old coot done this time Mike? :rolleyes:
He got a little carried away with the rb30 for the race car and forgot to put the grubscrew oil restrictors in! Only remembered when he was fitting the turbo to the exhaust manifold. Had to take head and surrounding shit off to fit them!
The two 6mm holes would have drowned the head in oil for sure lol.
I am hoping to go, but only if I get the car finished in time and sorted. If not then I wont bother going.
Turbo is assembled and bolted on loosely. Everything appears good so far. Need to get oil and water lines sorted now!
wow man that is intense..
when you threw the motor it did u have the blower off cos that engine mount would be a nightmare to tighten...
lol im sure you wont die before I get it done. Finished mounting the new intercooler and nearly finished off the new charger outlet piping which got destroyed when I removed it off the charger...that threebond sure sticks lol.
Weve been working on the race car for the last few weeks so there hasnt been much time to get my own shit done :(
Hopefully tomorrow if bathurst doesnt catch too much of my attention I will be working on the exhaust!!!
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
