I had a look at the mufflers, the actual muffler shell is about 2-3mm bigger then the actual 4" in and out of it, so there is no real lip to catch so to speak. Suprising how compact these mufflers are.
The flex pipe in my setup is actually quite high up, from what I can see at the moment, the lowest part of my whole exhaust is at the base of the dump pipe where it comes out from the firewall. But, if I do make some kind of shield around the flex pipe, it may look like a cat! That could come in handy lol.
  • 3 months later...
Its on hold atm. Busy working on the race car and helping my old man work on his HR build. Add a gf into the mix and there just isnt enough hours to get much done lol.
I have supercharger pulleys machined up and ready to bolt on and pretty well everything done, just need the time to start fitting/hooking it all up!
  • 4 weeks later...
Damn that was an epic read. Got goosebumps from excitement. A really bloody nice job Mike. Nik here from email. Mate let me know if you ever want to give away the twin charge beast at all. Btw did customs charge a lot for those egt sensors a few years back? And you on another ECU? Finally, still E85?
Sorry mate questions galore, buy one get hundreds free.
    • Hi all, I’ve just finished fitting the timing belt on my RB25, following the standard procedure: rotate the crank twice, release the tensioner, then tighten it down. The belt feels tight, and you can see that clearly in the picture below I’ve heard some people say it’s actually better for the belt to be slightly loose rather than too tight, as excessive tension can lead to snapping. So that’s in the back of my mind. What I’m seeing is this:  • At idle, the belt looks fine.  • But when cranking and especially when revving (around 3–4,000 RPM), there’s a momentary flap/flex or flicker in the belt, which I’ve tried to capture in the video. So my question is — based on what you see, is this slight belt movement something you’d consider normal, or am I just being OCD? Could this amount of movement cause sync issues? Or is it just a harmless bit of flex under load?   from what I know belt flap and flex is expected when crank spins up and pull cam with it Would appreciate any thoughts or similar experiences.     IMG_7656.mov IMG_7657.mov
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
