those pics are all 4 years old, im working hard today should have some good new pics to share later tonite
I see on another forum you commented the car has been tuned and had a few shakedown runs... Please share 88/75 results on e85 :)
just dynoed on weds, and went to the track yesterday - car is making wayyy too much power doing 4wheel burnouts like its on ice skates. will have a big update with pics and vids coming later today
  • Replies 136
I see on another forum you commented the car has been tuned and had a few shakedown runs... Please share 88/75 results on e85 :D
full updates posted here: http://forums.nicoclub.com/zerothread/4827...-tuner-shootout
final vmount pics:
bubbler tank for vmount:
rear susp is back under the knife, but shocks are inverted
on the dyno, 100% RWD:
^^jeff evans tuning
^^final 88-75 dyno at 20 psi on E85 - too laggy. will upload a fun dyno vid tonite or tomorrow
theres 4 weeks left and TONS of work to do still, will be swapping on a prototype S300 turbo from BW shortly! dont know if ill be able to post much more until after the event, the heat is on and clock is ticking
Edited by Full-Race Geoff
Would be great if you can post details/results on the new s300 and the current 88/75 in this thread after the event:
http://www.skylinesaustralia.com/forums/Gt...mp;hl=gt35+t04z
Cheers and gl.
Cheers and gl.
prototype borgwarner turbo just arrived. currently waiting on the new tial MVR wastegate - FINALLY shipping next week - these things should be sick!
more pics coming soon
Prototype BW turbo... titanium wheels?
Out of interest did you ever end up switching to the S300SX 83/75 before changing again now? Seems like a good option for a stock stroke RB26 but there is so little info on these turbos on RB's.
Edited by bigmikespec
i have the 83-72 but in bullseye power. no figures to report as the car is still in bits.
i see that they have tried reducing the inlet to 100mm 4" instead of the pain in the ass 5.5" inlet...
Ahh, what do Bullseye do to BW turbos to make them "special"? 5.5"inlet what a beast!
i strongly recommend that you use 100% genuine borgwarner airwerks turbochargers!!! Bullseye power is a knockoff of the BorgWarner, it is not the same.
here is the latest update for you guys:
To start this installment, many hardcore car guy know that the best suspension in the world is MOTON. Seriously - nothing else comes close. I researched my options - considered ohlins, bilstein, kw, penske but at the end of the day, none had what i was looking for except Moton. I HATE upgrading parts and only want to buy good suspension once, so i bit the bullet and what showed up was heavenly. The quality of these absolutely exceeded expectation, and im blown away (im a very picky engineer, this doesnt happen often) suspension of this caliber is seriously next level :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown :bowdown MOTON
^^ a total thing of beauty. Moton double adjustables (15 independant bump and rebound settings, blowoff valve system for high speed bump control, huge main piston, remote reservoir compression adjusters mounted on swivel banjo fittings (makes mounting them easy!), and 2.25" spring hardware.
^^this is the top-secret R14 front suspension ive never shown anyone before. consider yourselves lucky :rotflmao the Motons fit so perfect, its like the motons were just meant to be..
this is showing the drivers side remote reservoir compression adjuster
(pass side)
now to the rear --
installed (but waiting on the tender springs to arrive)
reservoir located, you can also see the fuel pump wiring
easy to see how the adjusters are mounted facing inwards, easy to access without removing the wheel
tire clearance at full droop
tire clearance at full bump
both reservoirs mounted, and the wing mount i am building now from 0.035 4130 cromoly
NEW prototype BorgWarner Twinscroll Turbo - dubbed S300'P'
^^^look at the super badass turbine wheel geometry and my favorite feature of all, the vband compressor hsg to CHRA. soooo slick. I am looking to spool 1000rpm quicker and make 700+whp at 30psi boost... this should do it.
the legendary extended tip compressor wheel design, this is only 61mm inducer / 83mm exducer turbo, just like a GT35R but it moves 72lb/min at full-tilt, HUGE airflow for this small of a turbo (35R is 62lb/min for example). take a look at the far tip you can see the little "peak" that is mountain shaped on the top of each blade? thats the extended tip
getting ready for the charge pipe modification
4" downpipe flange welded on
^^old vs new... you can see how much smaller the new turbo really is
^^got the manifold and downpipe 2000degree HPC coated, and will use DEI heat wrap on top of the coating to further reduce engine bay temps
Front Aero
^^front splitter mounted on the car, you can also see the radiator ducting. coolers will be remounted and ducted next
^^strong enough for 330lbs @ 0mph, should handle 300+lbs downforce at 170mph!
Rear diffuser
to make a functional rear diffuser, it requires that there be an area with no obtrustions to block air from exiting under the chassis or from behind the tires. I started by cutting the quarter panels level with the frame rail, and then i cut out the spare tire well
^^cutting quarter panels level with the frame rail
^^removing spare tire well
^^20 ga steel plate fabricated, and mig tack'd in place.
^^welds cleaned up, spray painted grey
flat bottom rear is finished! now time to bolt up the diffuser when it gets back from powdercoat on monday :naughty
this bumper will be trimmed generously!
another shot of the rear, but this time the new spindles with proper toe rod geometry is installed
update3.jpg as she sits tonite, getting ready for a looong weekend!
now i have to corner weight the car, align it, and do a few tweaks from my friends from M-workz and motoIQ, then i can finish the aero, and turbo for one last update before the race. see you guys for one last update in 1 week!
Thanks for taking the time to share this with us mate, it's awesome! I especially like how you just don't fark around, you just chop it.
my friend has a skateboard that on the bottom says "Scared Money Don't Make NONE" it became a joke around here but its the truth, if youre sitting around bullsh!tting you wont get anything done -- so cut the bitch!! we got work to do, no time to sit! haha
This is my favourite build up ever! Thank you for sharing, you have carried out some very skillful work and provided alot of insight. Keep up the good work! Hope it all comes together in time for you.
LOVE IT! now it's getting very serious mate. no real criticism I can think of. should be very fast. ;) thanks for sharing.
wow that's some pretty epic dynamic camber. Have you measured bump steer, and dynamic camber after all your changed?
bumpsteer is perfect -- 8.50" inch traction rod, 12.25" RUCA - i suggest anyone with an R33/R34 or a modified R32 rear subframe run this link length
great test of the front splitter that pic is a crack up.
I think I have spotted an issue at the rear......you have no fuel tank....at least you have space for the diffuser.
we have been struggling with the same issue, fuel tank, 2nd radiator for the water to air intercooler and a diffuser all meant to go in the same spot
only s13/r32 have the fuel tank there. s14/r33/r34 have the fuel tank above and in front of the rear subframe (under the back seat)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
