You didn't get the transparent paint!!! It basically looks like apple juice, but a different colour. You can see right through it but it's tinted :)
It should do the job though. You can just get another couple of globes for like a buck and use the proper paint next time.
yea dude i couldnt find the paint you were saying....hope this works for me....also i have a set of those orange condoms for the bigger proper globes ...so i will try them also...
Any idea's if the paint i used will work?
and i couldnt find a orange nail polish althought i found a nice orangeee gliter one... :hippy: but too many chiks were giving me the eye so i had to leave that area asap!
:band:
So did it work????
i have brought some more globes like the ones i had....they dont flicker...and im just waiting for paint to dry...so still 50/50.....
those globes you suggested i had a look for them but the shop nearest to me was closed until jan 2nd.....so didnt have a chance to buy em.... but i will when it re opens and see what they are like...
so atm waiting for paint to dry.... did you see the paint think its gona work?
It should work, but if it's too thick it could be a bit dull. Keep us posted. And take a photo of the end product with the lights flashing...... probably have to take a few shots to get one with the lights illuminated... :)
that's the one... i just looked at some blue and some orange paint and that's what i have too.
ok dudes i painted the globes and they turned out ok....but one was thicker than the other...
then i found these for my old globes which didnt have the flicker problem...and it ened up being a happy ending.....
thanks for all the help and suggestions ppl!
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
