Hey all, I had a crazy idea last night and I decided I wanted to put an SR20VE Head on an SR20DE S14 Block.
Question is, will this work?
I see people saying stuff about the solenoids, is that a big problem relocating them?
Also I see people getting custom intake manifolds made up, can't I just use the SR20DE Intake manifold?
I may not necessarily do this but I am just very curious, and hopefully the more knowledgable members out there can clear some stuff up for me.
Cheers!
https://www.sau.com.au/forums/topic/306986-sr20ve-and-sr20de/
he means FWD engines. however it can be done as far as putting them in a rwd car, just takes a bit more work (not sure how much though). i know someone that had a fwd engine in a datsun. had to alter the firewall to fit the distributor in though as the rwd engines don't use the dizzy. not sure if the VE does or not.
the s14 manifold may just bolt straight up as the stud pattern may be the same, just the fwd manifolds are designed to feed from the back of the motor (gearbox end)
i just went through a few forums and most of them don't have much useful info. people have asked the question about putting a rwd engine in a fwd car or vice versa and 99% of the answers are just "no it won't" or "why not just get the right motor?" and other useless responses, yet most of the people saying that don't know why they don't fit. i managed to find a few posts that actually explained the differences (there were plenty of posts about differences in spec, but not about physical differences such as engine mount locations etc). one of the main problems is the starter motor mounts differently, however i did find a pic of someone who had worked around this with a bit of fabrication. still not sure about the intake manifold though.
i can't remember how much work the guy i know had to do to get his to fit.
True that, nissanexa.com just aren't as good as here! but saying that if you were getting into contact with "nxtacy" and another memeber they have done this and spent a lot of money and know what their talking about, just try them.
I have a SR20 vvl head on a gtir short motor mounted in a datsun 1600 with an r33 gtst gearbox behind it...yes mods have to be made but it is certainly something that can be done .
Solenoids can be reloacted quite easily ..but i chose to alter the firewall to suit & use the original dizzy body only for the trigger to run a coil on plug setup.
Last pic is when i had the gtir head on it as well ..as it will still run the quad throttle bodies.
Thats neat man! Did you use a GTiR block? Or did the SR20VE Block fit straight in?
Also what intake manifold did you use? and the wiring? Will normal SR20DE Loom do the job? I will get an aftermarket management system to get it all tuned up.
Cheers.
Also where can I find an SR20VE head, got any ideas?
If your going to go NA SRVE. Put an SR16VE head on an SR20VE block. This is an East West set up. I have seen builds of people pulling oer 150 NA KW wth this set up
Its going into a Silvia, RWD. East West setup? Does that mean FWD?
I Am going to use an S14 SR20DE Block, with an SR20VE Head.
Only problems I can see is, wiring, intake manifold, and the Dizzy, not sure how the hell that is going to fit behind the engine.
Can anyone advise me?
  • 4 months later...
Yes it will work
use the s13 block and the ve oil pump
U need to machine the cam chain drive if you want to run adjustable gears due to the different style cam chain
Also there is a oil return to be blocked and a vvt line to be drilled and plumbed , seriously its a very easy swap
6boost make a manifold for it as well
The intake has to be custom made but it has a flange halfway down the intake which you can bolt to
Make the plenum chamber about 5 litre for best power and throttle response
Hey mate, lots of information here: http://nissansilvia.com/forums/index.php?s...;st=0&fcat=
http://nissansilvia.com/forums/index.php?s...p;#entry5558260
There is a fair bot of cost involved in doing it, but parts are becoming more readily available and there are a number of them being built on NS.com
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
