what a controversial race......webber was flying.....literally.....Ferrari got f**ked up by the safety cars....who let Hamilton in 2nd place through and held up the ferrari's 3rd and 4th.....hamilton got a drive through because of overtaking a safety car but the position loss for the ferrari's meant that the drive through wasnt justified as he didnt loose position......the ferrari's were looking strong for the race....and now we know for a fact that webber cant overtake
They say that Red Bull gives you wings but that was just ridiculous
-D
  • Replies 235
I seem to recall several instances of Webber overtaking before. Kovalainen braked 80 metres earlier than he was supposed to. Naturally Webber wasn't expecting him to stop in front of him so early before the corner. I'm sure you're aware of how quickly F1 cars can stop, if the guy in front of you brakes when you don't expect him to you have no time to react. I'm not saying Webber didn't play a role in the crash, I would say drafting him that way was probably unnecessary given that he would have got past Kovalainen soon enough anyway, but he was racing. I'm not surprised he didn't expect Kovalainen to stop so far from the corner.
+1 for Kobayashi......what a solid drive.....driver of the race i reackon......he did something 53 laps on the tires that he started on.....and he was matching Hamilton's 1:39:xxx after lap 38 or so......thrashed tires and he was still getting the performance out of them
and 5 second penalties to the field that ignored the yellow flag!!! WTF
that 5 second penalty really did f**k all to the end result....it should have been out of the points for breaching the yellow flag rules and 5 spot grid penalty at the next GP
i know typical FIA...
"We are going to to punish them all for breaking the rules"
public "finally"
FIA "now boy's count to five........... done!!!"
  • 4 months later...
well what an interesting end to the season.....last race and still 4 drivers in contention of the drivers title.....
well done to Mark Webber for an awesome drive this season. Well at least not blowing up engines like he used to with Williams :rolleyes: awesome drive throughout the season by Vettel....that man is destined for more championships in the future....Ferrari came out of pretty much no where to have Alonso fight for the title and only 3 places separated him from the title :P once again awesome season in F1 with a whole heap of thrills and spills....cant wait for next season with a whole heap of rule changes and different tire suppliers :blink:
Vettel thoroughly deserved the title too imo. Pity Ferrari fked Fernando's chances with the pit stop though... Got a feeling Luca won't be impressed at all!!
if Luca finds out whose fault it is they might not stay in the job for long lol.....ahh well you dont win or lose a championship in one race.....its what has happened throughout the year
  • 3 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
