Hey all !!!!!
I have had my stagea seres 2 RS4-S for just over a year now and i love it to bits, maybe more than the misses!!
After not having to spend a sent on this beast for over a year i just got my clutch replaced with a xtreme heavy duty organic, nothing to spectacular, but its my daily driver aswell as a fun car on weekends.
Since the new clutch i have been driving it a little harder and go figure the turbo has started making noises!
I have had it checked by 2 very knowledgeable people (as im very untrusting) and they have both said that the main bearing is about to go.
since the S2 turbos are all nylon or plastic internals I have been told that the internals are not repairable with a stock parts.
I have been given a couple options spend just over $2000 buks to get a garrett 30 shoved into the standard housing which would be awsome, or get a 2nd hand one thats in good nick!
I have no budget at all this is my daily driver!! im saving for my wedding and have nothing to sell to get some quick bucks.
What im after is a Standard Series 2 Turbo that has been pulled out of a stagea because of a new turbo going in. (ie not a screwed on)
If anyone can help me or just shout some telephone numbers at me to some places that might have Turbos laying around that have been pulled out!
im not prepared to spend that money on a new turbo yet!!!
but i just need to get out of trouble for the time being!
Please help im a loyal stagea man and i always give a wave to all you nutters who drive these baby's (even if i dont get wave back)
Is some of you could lend a needy guy a hand i would love it cheers!!!!
https://www.sau.com.au/forums/topic/307018-need-standard-series-2-stagea-turbo/
Andrew, you're looking at roughly $300 for a second hand turbo. Any turbo would do for now until you can save up the $700-$900 for a stock rebuild or hi-flow or $2000 for an aftermarket unit.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
