Sorry admin i put this on the SA forums aswell please dont kill me i need some help
Hey all !!!!! im from SA (dont judge me)
I have had my stagea seres 2 RS4-S for just over a year now and i love it to bits, maybe more than the misses!!
After not having to spend a sent on this beast for over a year i just got my clutch replaced with a xtreme heavy duty organic, nothing to spectacular, but its my daily driver aswell as a fun car on weekends.
Since the new clutch i have been driving it a little harder and go figure the turbo has started making noises!
I have had it checked by 2 very knowledgeable people (as im very untrusting) and they have both said that the main bearing is about to go.
since the S2 turbos are all nylon or plastic internals I have been told that the internals are not repairable with a stock parts.
I have been given a couple options spend just over $2000 buks to get a garrett 30 shoved into the standard housing which would be awsome, or get a 2nd hand one thats in good nick!
I have no budget at all this is my daily driver!! im saving for my wedding and have nothing to sell to get some quick bucks.
What im after is a Standard Series 2 Turbo that has been pulled out of a stagea because of a new turbo going in. (ie not a screwed on)
If anyone can help me or just shout some telephone numbers at me to some places that might have Turbos laying around that have been pulled out!
im not prepared to spend that money on a new turbo yet!!!
but i just need to get out of trouble for the time being!
Please help im a loyal stagea man and i always give a wave to all you nutters who drive these baby's (even if i dont get wave back)
Is some of you could lend a needy guy a hand i would love it cheers!!!!
https://www.sau.com.au/forums/topic/307019-need-standard-series-2-stagea-turbo/
Hi Andrew, I have one in good condition. Removed it because I upgraded. But I'm in QLD, so I'd have to post/courier it. I'm sure some of the SA guys will chime in soon if anyone has one, or even if there are any good wreckers down there. Also don't refine your search to just S2 stagea's, R34 GTT turbos are the same.
yeh how much mate???
i haven't received much feed back from sa :blink:
tangles is your man to speak to about turbos and stagea combos... at the end of the day id have a guess and say ull need to look into fuel upgrades if u go nuts on your turbos coz the injectors will be peaking out soon enough... correct me if im wrong... but tangles can give u the run down of exactly what to do! and wherre to do it (were both adelaide boys ourself)
cheers mate, i wish i had money then i could go and do the right thing and whack a nice sized turbo on it, but i havent im gonna have to fit the turbo myself im so short on cash at the moment, im just looking for a standard one to swap over on it!
i haven't received much feed back from sa :D
i'll be happy with $300, plus courier costs. if you have no luck down there and get desperate PM me. Know any good couriers that will deliver without having an account with them?
Have had good door to door service from these people: http://www.interparcel.com.au/
Are you sure it is not an exhaust manifold gasket leak?
Before you buy a new one I would make 100% sure that it is the turbo. My experience is that they go bang or they work with not much in between. If you are determined to buy a 2nd hand turbo any RB25DET turbo will do the job. The 34GT-t/S2 stagea version has a slightly larger turbine housing.
Yeh exhaust leak was my first thought, but its definitely the bearing. had 2 knowledgeable people look at it one works in a turbo shop(but they cant get any standard series 2 ones).
At the moment its not broken!! but i just dont want it to go pop
ta for the thought though!
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
