Basically all you can do, I run an FTO as well with tiptronic, been through 2 trans at 150,000K. Both started acting up a bit, came good, started shifting hard, then ultimately ran out of drive. I don't think you can run stock autos behind high reving performance engines and have them live for too long.
yeh true it done it once yesterday but came good i went into work then come out then it drove good i think it mite be when it gets hot or something but today drove the exact same places as yesterday and everything too see and it worked fine i got no idea but prob is about 2 die hope it can last till get green ps and ill get manual huh.gif
re25de will live a well longer then 200ks. they can be strange like that, it sounds like more then likly an electrical problem. or something to do with the auto. but check you fuel pressure, could be a weak pump. they tend to play up when there on thier last legs. or may sound stupid, did you have fuel in it...
panda.
yeh it normal did happen when i just had refueled like that day but i think its a electrical problem my mate always had his foot on were the ecu is behind and like pushed on it and that and i pushed all plugs in hard and done that with all the electrics and it gone fine ever since but happened other day but he had his foot on it again soooo that mite be reason not sure
