hey guys
lately ive been experiencing problems with my gearbox. at a specific rev the box will crunch
between 1st to 2nd and 2nd to third.
but also if im down gearing i can hear a winding sound when in second gear, even if that clutch is
in!
ive been searching on this forum about box rebuilds and want ti get all the bearings replaced along
with the pilot bearing and throw out bearing but since i dont know much i dont want to go to the guys
and say rebuild this the will rip me off and probly change synchos and stuff that dont need changing
all the gears go in and out with out a problem just dont know but the high rev crunching.
can someone please help and tell me what i do need to replaced so i dont get ripped of :)
and im also going to to the diff and gearbox guy in seven hills apprently he's the best with rb boxes
cheers every one !!!!
https://www.sau.com.au/forums/topic/307028-gtst-box-help/
As jack said mate if your crunching gears at hi rpm your syncros are most likely glazed and 90% worn out.
How many kms are on the box? how much power do you have? how hard is it driven? what oil have you been using and how often has it been changed? The answers to these questions will tell you if it is time for a birthday or not.
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5076124
its done 120 xxx ks not sure what oil its just been imported 2 years ago
ive gotten quotes for 1100 for 2nd 3rd synchos and bearings
so its the sync that makes it crunch
ill try the oil 50/50
ive been told to use the nulon additive as well
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5076510
the box sounds f**ked so no matter wat you do to it atm its still gona be f**ked, 120,000kms on a import manual isnt that bad if i were you i'd get the thing rebuilt properly the first time.
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5076616
  battery said:
i'd chuck some redline oil in it.
else you gonna be up for like 2k to get a rebuild.....
Why you would even consider rebuilding an RB20 box is beyond me when you can pick them up for $200+
$1100 for synchros & bearings or you could buy a 25 box for around that and if you plan on further power mods you wont have to upgrade later or worry as much about breaking another box :P
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5076768
R33 GTST's have RB25DET boxes in them from the factory Ben :)
Try some light weight redline shock proof oil and ease up on the old girl and it might see you out. Other wise get it rebuilt not just repaired, next thing you know you will be crunching 5th ad it will blow. Do it right and do it once.
Good luck.
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5076789
yer i know the gearbox cost around that much but your taking a chance with that too.
id rather pay more and know its not going to fair for a long time
lol andthe guy who was talking bout rb20 boxes
cheers for the info guys ill keep you posted :D
https://www.sau.com.au/forums/topic/307028-gtst-box-help/#findComment-5077836
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 馃槑
    • Cool, I鈥檓 just down Sydney today. Not much time to get online.
