hey guys and girls , before i start i'm going to say i just searched for 20 mins and i must be blind , but everyone has answered this WRONG ..
I just bought a genuine GTR wing , and i know its genuine coz i pulled it off a crashed one just around 1 hour ago lol ..
Now only realising as i went out to look at mind everything seems like it will fit BUT there are 3 screws in the centre lower wing lip thingo under the main blade that bolts to the boot top .. Now i don't know if every gtr has this , being a vspec but what is best way at drilling it and does anyone have any personal info about fitting one
https://www.sau.com.au/forums/topic/307031-genuine-r33-gtr-wing/
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
