Just took the r33 gtst to the shops and on the way back, went to boost and had a large cloud of grey smoke come out the back, and the car will no longer boost so im assuming my turbo has given up
Currently the car has minor mods, FMIC, 3inch exhaust and was running 10psi.
For a bit of scope, im happy with how the car preforms and am not looking for more power. Id prefer to maintain the early response the stock turbo gives, and not have to get a new ECU and tune. But im not against a minor power upgrade if the bang for buck is there.
So what are my options? New turbo or is a rebuild with steel wheel worth it?
What costs am i looking at?
https://www.sau.com.au/forums/topic/307096-turbo-blown-what-are-my-options/
Link?
Is that rebuild or new?
Also been reading around about some people killing engines with the ceramic dust created when the turbo lets go, how probable is it that this could have happened? as i recall i gave it a punch at about 3500rpm and it let go instantly once it left vacuum, and i held it there long enough for me to look down and read the boost gauge at 0 before i backed off.
Edited by Sparky206
Cheapest and easiest way would be get a second hand stock turbo (see above :laugh:) because you won't have to modify anything to fit.
Having said that, you don't know how much life the new turbo has left in it.
*update*
Well I've gone with the hypergear hi flow option, sent it off last week.
When i took the turbo off it was the shaft that had sheered off, flush with the seals. Few little gouge marks where the wheel had impacted the housing on the way out, but other than that nothing too major.
Got to thinking over the last week to where the shaft and wheel ended up, so it took the exhaust apart tonight and im glad i did.
Starting at the dump pipe, you can see a slight mark where the wheel has spiraled down the dump pipe, looking in the other end theres a solid yellowish mark where the wheels impacted, followed by lots of little mounds, kind of like when you throw a clump of dirt at concrete, except this time with ceramic. After that i found the majority of my exhaust wheel at the beginning of the cat, in about a million pieces.
But, there was no sign of the shaft which the wheel was connected too that sheered off. Im not too familiar with the setup of the stock internals, but i assumed that the shaft would have been metalic, and survived the trip down the dump pipe. There's no way it got through the cat, it wasnt damaged at all, and nothing bigger than a grain of rice is passing through there, so any idea where it could be? or am i wrong in presuming the shaft is metal, and it has infact blown up.
Also, there's a bit of mention on ingesting ceramic dust back into the cylinder, causing damage.
Is this likely to occur?
With the exhaust side being separate to the intake side, and the car accelerating at time of failure im having trouble to see how people have had this occur
Cheers guys, thanks for the informative replys so far
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
