it would struggle to make power due to lower compression you would also need exhaust manifolds and non turbo ECU
are you already on your P's, and whats the rule going to say if you have said car registered in your name before the rule comes in
https://www.sau.com.au/forums/topic/307099-r32-r33/#findComment-5074383
hey guys,
i was just wondering if it would be posible to take a turbo skyline (R32 or R33) and take the turbo off while on my ps because of the new p plate laws coming for south australia and put it back on after im off my ps ?? or would there be engine mods needed or wateva? Thanks.
ummm no.!
you will lose way to much power different compression ratios between turbo/non turbo models.
get a different car put the line in the shed until ur off ya P plates or just buy a non turbo car if ur that worried.
regards
Allan.M
https://www.sau.com.au/forums/topic/307099-r32-r33/#findComment-5074386
if the law does come in, then selling a non turbo skyline down the track will be easier than selling one now without those laws :D
hahah Allan
non turbo R34 are very cheap from japan
EDIt
if your choice is only 32 or 33 get the 33 with a RB25de as the 20 would have even less guts again
R33 = RB25
R32 = RB20
GTS = DE
GTSt = DET
R33 GTS4 = RB25DE
https://www.sau.com.au/forums/topic/307099-r32-r33/#findComment-5074408
hahah Allan
EDIt
R33 = RB25
R32 = RB20
GTS = DE
GTSt = DET
R33 GTS4 = RB25DE
You missed a few out
R32 - RB25DE Seen a few of these getting around
And the very rare R32 - RB26DE but I doubt you'd ever find one.
https://www.sau.com.au/forums/topic/307099-r32-r33/#findComment-5074446
a little more info :D
didnt know you could get a CA18 in a R32, and looks like all the 25's were double cams only a couple 20 single cams
The R32 range:
GXi - The bare basic model R32 1.8 litre, rwd, non-turbo, no extras.
GTE - 2 litre family model, four door, non turbo, single overhead cam.
GTS - 2 ltr, in-line 6. DOHC, EFI, 2 & 4 drs, RWD, standard sports model.
GTS25 - 2.5ltr, in-line 6. DOHC, EFI, 2 & 4 drs, RWD, non-turbo, sports model.
GTSt - 2 ltr, in-line 6 cyl, DOHC, EFI, 2 & 4 drs, RWD, turbo charged sports car.
GTS4 - 2 ltr, in-line 6 cyl, DOHC, EFI, 2 & 4 drs, 4WD, turbo - some feature GTR specs (eg ATTESSA 4WD)
GTR - 2.6ltr, in-line 6 cyl DOHC, EFI, 2 dr, twin turbo, 4WS, 4WD, ABS, HICAS...
Basic R32 Specification Chart:
Model Engine Type Description Power Output CC Drive Doors GXi CA18i 1.8litre 4cyl 91PS/5200rpm 1809 RWD 4 door
GTE RB20E 2ltr, 6 cyl, single cam 97kw@5600rpm 172Nm@4400rpm 1998 RWD 4 door
GTS RB20DE 2ltr, 6 cyl, double overhead cam 116kw@6400rpm 184Nm@5200rpm 1998 RWD 2 & 4 dr
GTS25 RB25DE 2.5ltr, 6 cyl, DOHC 142kw@6400rpm 231Nm@4800rpm 2498 RWD 2 & 4 dr
GTSt RB20DET 2ltr, 6cyl, dohc, turbo 160kw@6400rpm 263Nm@3200rpm 1998 RWD 2 & 4 dr
GTS4 RB20DET 2ltr, 6cyl, dohc, turbo 160kw@6400rpm 263Nm@3200rpm 1998 4WD 2 & 4 dr
GTR RB26DETT 2.6ltr, 6cyl, twin turbo 208kw@6800rpm 368Nm@4400rpm 2568 4WD 2 dr
Decifering the Engine name:
RB - series of engine 20 / 25 / 26 - capacity (20~1998cc / 25~2497cc / 26~2597cc) D - Double Overhead Cam (or DOHC) E - EFI (Electronic fuel injection) T /TT - Turbo / twin turbo
Engine Type:
The R32 generally featured the RB series of engine in all instances except for in the case of the R32 GXi which feature the CA18i engine. This was a four cylinder, 1.8 litre normally aspirated engine.
Special models:
During and after general production, a handful of special models were released in small numbers. These rare cars generally featured a small variation from the normal, and seemed to be more like test models than anything. The Autech R32 is an example of this. The Autech R32 was tuned by Autech and was basically a four door R32 GTR, without the turbos, as it housed an RB26DE in its engine bay and an automatic gearbox. You can deduce from the name that the engine was a 2.6 litre DOHC EFI in-line six normally aspirated variant. Very good for pulling trailers since they have tonnes of torque.
https://www.sau.com.au/forums/topic/307099-r32-r33/#findComment-5074486
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
