R32 - R33
samo 123
 Share
hey guys,
i was just wondering if it would be posible to take a turbo skyline (R32 or R33) and take the turbo off while on my ps because of the new p plate laws coming for south australia and put it back on after im off my ps ?? or would there be engine mods needed or wateva? Thanks.
it would struggle to make power due to lower compression you would also need exhaust manifolds and non turbo ECU
are you already on your P's, and whats the rule going to say if you have said car registered in your name before the rule comes in
hey guys,
ummm no.!
you will lose way to much power different compression ratios between turbo/non turbo models.
get a different car put the line in the shed until ur off ya P plates or just buy a non turbo car if ur that worried.
regards
Allan.M
if the law does come in, then selling a non turbo skyline down the track will be easier than selling one now without those laws :D
hahah Allan
non turbo R34 are very cheap from japan
EDIt
if your choice is only 32 or 33 get the 33 with a RB25de as the 20 would have even less guts again
R33 = RB25
R32 = RB20
GTS = DE
GTSt = DET
R33 GTS4 = RB25DE
hahah Allan
EDIt
R33 = RB25
R32 = RB20
GTS = DE
GTSt = DET
R33 GTS4 = RB25DE
You missed a few out
R32 - RB25DE Seen a few of these getting around
And the very rare R32 - RB26DE but I doubt you'd ever find one.
not 100% sure chad but the 25 in the R32 might be single cam ?? i know there were some funny variants getting around
and the R32 autech would be amazing but dear as
and they were all 4door and auto
a little more info :D
didnt know you could get a CA18 in a R32, and looks like all the 25's were double cams only a couple 20 single cams
The R32 range:
GXi - The bare basic model R32 1.8 litre, rwd, non-turbo, no extras.
GTE - 2 litre family model, four door, non turbo, single overhead cam.
GTS - 2 ltr, in-line 6. DOHC, EFI, 2 & 4 drs, RWD, standard sports model.
GTS25 - 2.5ltr, in-line 6. DOHC, EFI, 2 & 4 drs, RWD, non-turbo, sports model.
GTSt - 2 ltr, in-line 6 cyl, DOHC, EFI, 2 & 4 drs, RWD, turbo charged sports car.
GTS4 - 2 ltr, in-line 6 cyl, DOHC, EFI, 2 & 4 drs, 4WD, turbo - some feature GTR specs (eg ATTESSA 4WD)
GTR - 2.6ltr, in-line 6 cyl DOHC, EFI, 2 dr, twin turbo, 4WS, 4WD, ABS, HICAS...
Basic R32 Specification Chart:
Model Engine Type Description Power Output CC Drive Doors GXi CA18i 1.8litre 4cyl 91PS/5200rpm 1809 RWD 4 door
GTE RB20E 2ltr, 6 cyl, single cam 97kw@5600rpm 172Nm@4400rpm 1998 RWD 4 door
GTS RB20DE 2ltr, 6 cyl, double overhead cam 116kw@6400rpm 184Nm@5200rpm 1998 RWD 2 & 4 dr
GTS25 RB25DE 2.5ltr, 6 cyl, DOHC 142kw@6400rpm 231Nm@4800rpm 2498 RWD 2 & 4 dr
GTSt RB20DET 2ltr, 6cyl, dohc, turbo 160kw@6400rpm 263Nm@3200rpm 1998 RWD 2 & 4 dr
GTS4 RB20DET 2ltr, 6cyl, dohc, turbo 160kw@6400rpm 263Nm@3200rpm 1998 4WD 2 & 4 dr
GTR RB26DETT 2.6ltr, 6cyl, twin turbo 208kw@6800rpm 368Nm@4400rpm 2568 4WD 2 dr
Decifering the Engine name:
RB - series of engine 20 / 25 / 26 - capacity (20~1998cc / 25~2497cc / 26~2597cc) D - Double Overhead Cam (or DOHC) E - EFI (Electronic fuel injection) T /TT - Turbo / twin turbo
Engine Type:
The R32 generally featured the RB series of engine in all instances except for in the case of the R32 GXi which feature the CA18i engine. This was a four cylinder, 1.8 litre normally aspirated engine.
Special models:
During and after general production, a handful of special models were released in small numbers. These rare cars generally featured a small variation from the normal, and seemed to be more like test models than anything. The Autech R32 is an example of this. The Autech R32 was tuned by Autech and was basically a four door R32 GTR, without the turbos, as it housed an RB26DE in its engine bay and an automatic gearbox. You can deduce from the name that the engine was a 2.6 litre DOHC EFI in-line six normally aspirated variant. Very good for pulling trailers since they have tonnes of torque.
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
